Leaking freeze plug
I would suggest you to replace it permanently. For temporarily fixing, the leaking will stop for sometime, but when it leaks again, it will completely damage the freeze plug. Its better for you to replace it permanently. I did the same once. i fixed it temporarily, but i ended up paying for the replacement as well.
