How do i get the fault code?
i have got ABS fault and to fix it i have to get the ABS fault code so that the problem can be diagnosed correctly but there is one problem that i dont know where the code will show and how to get it. will it show somewhere on the dashboard?
Can someone please advise.
You can read code with OBD II fault reader. Usually these diagnostic tools are there in workshops, so visit any good workshop and they can read that fault code for you less than 50 -100 dhs. Hope it helps, and hope ABS must have some loose socket or wiring issue, as ABS modulation block is most expensive component.
