Cadillac General Discussion Forum | Cadillac ATS Forum | Cadillac CTS Forum | Cadillac STS Forum | Cadillac XTS Forum | Cadillac XLR Forum | Cadillac SRX Forum | Cadillac Escalade Forum
jabri
brake light switch
Brake light switch is located underside of the dash. You need to kneel inside the drivers side. You will notice the head screws just behind the brake pedal. basically, there is a cover over there that you need to remove. After removing the cover, you will see the brake light switch which is adjusted by bolta. Remove the switch by unscrewing the bolts and disconneting the electrical connection which supplies power to the switch. Connect the new switch over there and attach the eletic connection to the new switch. Screw the bolts back and put the cover back. Its done!
There is an Autoshop called Yellowhat in time square center on Shk. Zayed road. They have good stuff. ou can check there. But before buying, do look for the specification of brake light switch in your car manual first.
