Cadillac General Discussion Forum | Cadillac ATS Forum | Cadillac CTS Forum | Cadillac STS Forum | Cadillac XTS Forum | Cadillac XLR Forum | Cadillac SRX Forum | Cadillac Escalade Forum
Sign in to follow this
sidiqq
the front wheels are vibrating
SAME PROBLEM NOW front wheels are vibrating and for getting them changed each tire is for 2900 which is dam expensive.
Do any of you guys have idea where i could find same quality lower price tires please.
Though its an old post, but i think I can add some value for future members if they have similar issue. Vibration is usually caused by one of following things, so checking each is step by step solution.
-- Check the wheel balancing and make sure it shows ZERO on both sides of tire.
-- Check the wheel alignment including the toe-in, toe-out and camber alignment.
-- Check the wheel bearing
-- Check the harmonic balancer that is placed usually around the center axle to balance the car weight equally on both sides.
