1 minute ago, Chirag S. said:
@Rahimdadbhai, what is correct method in such situation to control the car?
Just drive and don't aim to fly the cars, you'll be fine.
These crazy stunts often lead to hospital and police station visits
  • Like (+1) 5
You are right.  @gaurav bhai, in worst case, if we are in same situation, what should we do? is there any method to get rid from this situation?
If you want to perform a stunt like this make sure you are prepared. Practice at slower speeds to make sure you are getting a straight lift and not side ways. Slowly increase your speed on each attempt to understand how your car reacts and you can prepare yourself for the final jump. Remember you are using natural sand which is always shifting as your ramp and do not have firm controlled ground. As @Gaurav bhai said, do not attempt stunts, but if you do prep yourself before you cause any incident.
At that speed you have very little time to react and also the impact is hard and difficult to get away, but counter steer and keeping up the power instead of letting go can help to some extent.
  • Like (+1) 5
Trust me you can never land up in such situation unless you plan to do such crazy stunt to let car fly of 40- 50 meters at the speed of 80 kmph. These were the sights that we used to witness on Faya, before authorities closed that dune to stop these stupidities.
See how hard landing he did, as explained by Rahim bhai
  • Totally Agree (+2) 2
Absolutely right. Perfect & self explanatory click!! So scary!!
2 minutes ago, Emmanuel said:
And this one ? WWW ?
looks like he was coming too fast and too close to the other Landcruiser, so he might have applied the braked agressively, causing the car to sink away in the soft sand and tip over.
Why aren't these guys using the flags or radios ?
  • Gaurav pinned this topic
  • Gaurav locked this topic
  • Gaurav unlocked this topic
  • Carnity unpinned this topic
