Emanuel Posted June 17, 2024 Share Posted June 17, 2024 On 2/10/2021 at 12:14 AM, Ilya said: Installed these Fast Deflation tire vales - absolutely love it. In Formula Tires got them at 550AED with the installation Deflating the tire in 15 sec (I normally do 2 meausures to catch the correct pressure, but in any case it takes another 5 sec per tire) Hi @Davie Chase, are these the ones you have installed? Are they still your favorite deflation method? Are yours the Apex brand and can you recommend the place you had yours installed? Hi @Looper, are yours the Apex brand? I read your more recent posts after Ilya's post and wonder if you overall still feel these are worth it. Any other recommendations on this point would be appreciated. Thanks Link to comment Share on other sites More sharing options...
Davie Smooth_Operator Posted June 17, 2024 Share Posted June 17, 2024 @Emanuel yes still my favorite method although you do have to be careful and make sure they seat correctly. I had mine done at Artic trucks and Offroad zone before that, as I have changed them one time and will again before the season gets underway around October time (just my preference to change for new) 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 19, 2024 Share Posted June 19, 2024 On 6/17/2024 at 4:48 PM, Davie Chase said: @Emanuel yes still my favorite method although you do have to be careful and make sure they seat correctly. I had mine done at Artic trucks and Offroad zone before that, as I have changed them one time and will again before the season gets underway around October time (just my preference to change for new) Thanks @Davie Chase. Do you have these with tire pressure sensors and a monitoring system? 2 Link to comment Share on other sites More sharing options...
Davie Smooth_Operator Posted June 19, 2024 Share Posted June 19, 2024 @Emanuel no just the cheaper version no sensors / monitoring Link to comment Share on other sites More sharing options...
Emanuel Posted June 20, 2024 Share Posted June 20, 2024 Thanks @Davie Chase. I'll give the stem removal tool a try first. The only con I can think of besides losing a stem or two (I have spares) is that the stem seat might lower over time making inflating problematic. Link to comment Share on other sites More sharing options...
RiadJL Posted June 20, 2024 Share Posted June 20, 2024 @Emanuel I can recommend the Apex RCVs: Not as fast as the other Apex valves but does the trick and you don't need to take off the tire to install - just screws onto existing valve. Takes about a minute to deflate from 35psi to 15psi per tire. If you do it the right way (open the valves one after the other) you can be deflated in all 4 tires in under 3 mins . Available on Amazon and install is easy - you can do it yourself 1 1 1 Link to comment Share on other sites More sharing options...
Emanuel Posted October 6, 2024 Share Posted October 6, 2024 (edited) On 11/23/2021 at 6:01 PM, Looper said: I screw this gauge and then deflate while monitoring the pressure to 10 psi. normally when I stop I am at 11-12 psi after the tire gets back to normal air temp. and it is quick way of accurately deflating, with less chance of over/under deflation. Hi @Looper - I found this version of the same tool but with clip-on chuck, which is amazing for ease of use. I use it to check my pressure during the drive when needed. https://www.amazon.ae/KATGROCHIR-Inflator-Accurate-Compressor-Motorcycle/dp/B0CDPVNMBZ/ref=sr_1_20?crid=3PX8VKGV2R6JT&dib=eyJ2IjoiMSJ9.yU41CJMh25JOGY5cDRZgZ3p7hbUdRI-9tcEzHZmVhuLqUEWKfARWT6DRy1xwRY-Gf2Nt0cMDOo_9W39bRPVf--aTax20Dng9GuT8zKZuY9E6zr15aIdIA_G71WPAU7P0NtcxkDfMs_HJDYEHOdmxM0UTbyiSQqR7odwjGHIpAAq92GcYmCB_vp4h-HhGgf8BfMfgOEW1KW0DwWBHy8tsQc2-RcE0ciimK2aNQd78-U3_5HXO7aEOruyfqaljVTg42iNn1jUl7sxploQEWwct9w_GthFg5GLwYbbMANO4Mro.1VE4xfaGE4M0qKgDJaPoCbc3bC6qRm_SamXqlZyTLeM&dib_tag=se&keywords=tire+inflator&qid=1728205110&sprefix=tire+%2Caps%2C316&sr=8-20 Edited October 6, 2024 by Emanuel Link to comment Share on other sites More sharing options...
Zubail Posted October 8, 2024 Share Posted October 8, 2024 @Emanuel Try Jaco, I and @Mike M. I saw also using it. amazing tool. it's not for deflation from 40 to 12, for inflation or adjusting very good, not leaking https://www.amazon.ae/JACO-Superior-Products-FlowPro-Inflator/dp/B01ETWXEWA/ref=sr_1_1_pp?crid=PVX9BGQ60CM4&dib=eyJ2IjoiMSJ9.8g_7gRXyZtLxhRrgIKTkOEA73JuMJvSjI5msVAiiAt7bTxc_DtY6r3UC8yGuqpg8S_POgH9HZbqekpbihHpq1bySD23AsTLa6MY2t12ecGSBQbSk_E0vjl04GCj7ls3Oh55BiJpK3s00J91tN4j0lG30QSCTHyY4iiP3W1e62MansuaXfbO_dV3--wRS6IXkNttsyfrOjsn1-q4U27Sr6w-eGomPCVYMfNdlb9hPijTgvvrdflR3KLurD0nhweJ2Gt73seTPluLq3z3PoE4qX67S-ZAtPmDs4dHKu2HrNYY.hUpPyDZlsQxeLkvzvXy8odXWXaJridZk2gZFX3h2Txk&dib_tag=se&keywords=jaco&qid=1728391448&sprefix=jaco%2Caps%2C217&sr=8-1&ufe=app_do%3Aamzn1.fos.b4f74a7b-9d54-420b-9003-7e54957e6f89 2 Link to comment Share on other sites More sharing options...
Mike M. Posted October 8, 2024 Share Posted October 8, 2024 (edited) 1 hour ago, Zubail said: @Emanuel Try Jaco, I and @Mike M. I saw also using it. amazing tool. it's not for deflation from 40 to 12, for inflation or adjusting very good, not leaking https://www.amazon.ae/JACO-Superior-Products-FlowPro-Inflator/dp/B01ETWXEWA/ref=sr_1_1_pp?crid=PVX9BGQ60CM4&dib=eyJ2IjoiMSJ9.8g_7gRXyZtLxhRrgIKTkOEA73JuMJvSjI5msVAiiAt7bTxc_DtY6r3UC8yGuqpg8S_POgH9HZbqekpbihHpq1bySD23AsTLa6MY2t12ecGSBQbSk_E0vjl04GCj7ls3Oh55BiJpK3s00J91tN4j0lG30QSCTHyY4iiP3W1e62MansuaXfbO_dV3--wRS6IXkNttsyfrOjsn1-q4U27Sr6w-eGomPCVYMfNdlb9hPijTgvvrdflR3KLurD0nhweJ2Gt73seTPluLq3z3PoE4qX67S-ZAtPmDs4dHKu2HrNYY.hUpPyDZlsQxeLkvzvXy8odXWXaJridZk2gZFX3h2Txk&dib_tag=se&keywords=jaco&qid=1728391448&sprefix=jaco%2Caps%2C217&sr=8-1&ufe=app_do%3Aamzn1.fos.b4f74a7b-9d54-420b-9003-7e54957e6f89 Thanks @Zubail yes i am using this, which i prefer over the ARB tyre inflator which leaks a lot. The Jaco has a patented deflating tip which does not leak, even when you move the gauge around. I recommend it as well for adjustments. For deflating, I have been using the below auto deflators for more than 2 years now and i can say they have been great. After a long-period use, i highly recommend it. You set the PSI once and you get the same results, every time. Takes usually around 3-4 minutes to deflate. What i do is i connect them first thing i park and by the time i have the flags up and a few quick hellos, the deflating is done. Hope this helps for anyone who is looking for an effortless deflating method. https://www.amazon.ae/J-T-Brooks-Automatic-Tire-Deflator-Atdp4/dp/B07P9VB7TW/ref=sr_1_37?crid=2VWJO73OGOUUU&dib=eyJ2IjoiMSJ9.Cqx1ILZkyPkiz63QBGI562TMYx-wxrL2VMAibiZ36se7DVV6KWvA_XpXHtZJctHmi1dMU1W9A89gPpkmH2eU5fu_sazKPhqLL1goInuIdGHnF5qW61vgFCk269b0X1Pz0hVap7QOpzHykr63RnK0uT-k4Ll13Yf193_3qrefUmHo4EKmYUCASPbiKu-dg0t6LzQYYomn6WkkHXjPM963IWIn7XgwRzwbUjA_t6OLJSCFwadIcC26WM1uyDW7hdtF2wkL3XwLZEHnYFMc4bBlRcwMZu19Wa5lAsxGVTQ89oQ.YlX6JL4_gbOThxm6-yH5Ep4hsyz6Zh2dMnPQQ6Jzzcs&dib_tag=se&keywords=deflator+auto&qid=1728391841&sprefix=deflator+aut%2Caps%2C192&sr=8-37&ufe=app_do%3Aamzn1.fos.b4f74a7b-9d54-420b-9003-7e54957e6f89 Edited October 8, 2024 by Mike M. 2 Link to comment Share on other sites More sharing options...
Luke K P Posted October 8, 2024 Share Posted October 8, 2024 been hunting for an inflator after my ARB one decided it would no longer give pressure readings accurately.. might give this JACO a shot. Thx @Zubail @Mike M. 1 Link to comment Share on other sites More sharing options...
