shadow79 Posted July 5, 2019 Share Posted July 5, 2019 (edited) Smells like the axel inners shot.... repaired in a sense that it was checked and repaired or just plop a can of grease and put the boot back.. Edited July 5, 2019 by shadow79 More info 1 Link to comment Share on other sites More sharing options...
Gaurav Posted July 5, 2019 Share Posted July 5, 2019 9 hours ago, SIDDIQUI AHMED said: If I drop the gasoline pedal at 60, absolutely no vibration is felt in 60-40 band. Then in this scenario it can't be wheel balancing, its more mechanically powered or engine related issue, that requires physical inspection to be 100% sure. Totally agree with @Barry and @shadow79 advise and those both are the quiet close possibility as it's vibrating only while hitting the gas. It's worth digging into how axle has been repaired earlier, because while axle is powered it may be causing this vibration. 2 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
desertdude Posted July 5, 2019 Share Posted July 5, 2019 Im going to make this thread even more confusing and say possible bad ignition coil or worn out joint on the drive shaft if it has one. 1 1 1 Link to comment Share on other sites More sharing options...
treks Posted July 6, 2019 Share Posted July 6, 2019 Bad ignition coil(s) will set misfire codes, but I do agree with you about the cause involving bad driveshaft(s). 2 Link to comment Share on other sites More sharing options...
SIDDIQUI AHMED Posted July 6, 2019 Author Share Posted July 6, 2019 On 7/5/2019 at 11:33 AM, shadow79 said: Smells like the axel inners shot.... repaired in a sense that it was checked and repaired or just plop a can of grease and put the boot back.. Yes exactly Mr. Adel cars & Bikes Al Quoz 3 guy did the same. They told me they took it for some lathe machine and put a new rubber cover with grease. 1 1 Link to comment Share on other sites More sharing options...
SIDDIQUI AHMED Posted July 6, 2019 Author Share Posted July 6, 2019 On 7/5/2019 at 8:56 PM, Gaurav said: Then in this scenario it can't be wheel balancing, its more mechanically powered or engine related issue, that requires physical inspection to be 100% sure. Totally agree with @Barry and @shadow79 advise and those both are the quiet close possibility as it's vibrating only while hitting the gas. It's worth digging into how axle has been repaired earlier, because while axle is powered it may be causing this vibration. The Authorized Dealer of Luxgen in DIP suggested to replace the entire Axle "Shaft Assembly Drive" as per the Picture. Can any member advise where to procure Luxgen Parts in U.A.E. or online. 1 1 Link to comment Share on other sites More sharing options...
desertdude Posted July 6, 2019 Share Posted July 6, 2019 2 minutes ago, SIDDIQUI AHMED said: The Authorized Dealer of Luxgen in DIP suggested to replace the entire Axle "Shaft Assembly Drive" as per the Picture. Can any member advise where to procure Luxgen Parts in U.A.E. or online. Luxgen parts! I swear and Im not kidding here the first time I even heard the name luxgen was in this thread. Wouldnt the dealer in DIP have parts for it? 1 2 Link to comment Share on other sites More sharing options...
shadow79 Posted July 6, 2019 Share Posted July 6, 2019 It's a China car you won't find it in the used unless it's a knock off of any known brand they do copy German us or Japanese Korean cars but it's a long shot or might as well be a wild chase 1 Link to comment Share on other sites More sharing options...
SIDDIQUI AHMED Posted July 7, 2019 Author Share Posted July 7, 2019 9 hours ago, desertdude said: Luxgen parts! I swear and Im not kidding here the first time I even heard the name luxgen was in this thread. Wouldnt the dealer in DIP have parts for it? He will arrange it and it takes 3-4 weeks 1 Link to comment Share on other sites More sharing options...
Gaurav Posted July 7, 2019 Share Posted July 7, 2019 54 minutes ago, SIDDIQUI AHMED said: He will arrange it and it takes 3-4 weeks Sorry to say this but if any car dealership take 3-4 weeks for getting parts, that means they themselves is not convince with that brand and just outsourcing parts from Oman, KSA or China just for the heck of it instead of stocking it here. Used car ownership is a marriage between the parts and service provided by dealer or outside workshop. If you can't find these, then you should be better changing this "UNSUPPORTED" brand with much loved brands in UAE, whose spare part type no:1, 2, 3 and scrap is readily available in a day's time. 1 1 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
