Emmanuel Posted December 5, 2020 Share Posted December 5, 2020 This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely. MUST READ AND TOTALLY AGREE: COVID19 Precautions MUST READ AND TOTALLY AGREE: BAN POST Two Way Radio Guidelines Every Off-roader brings his own radio, programmed to the frequencies described in below advice topic. We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out. Make sure your radio is fully charged. It will be your only way of communication while driving. Before buying, please carefully read below advice so you are informed properly on which model / cost / shops... No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it. Drive Details Level: Intermediate and above When: 11 December 2020, Friday Meeting time: 2:00 PM (SHARP - Without any exceptions) Meeting Point: https://goo.gl/maps/qTpBjsXfXkCekFMo9 Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water, snacks (for yourself), face mask, rubber gloves, enthusiasm and willingness to learn. Please also make sure you have all the equipment required on board as an Intermediate. THIS IS A COMPRESSOR ONLY DRIVE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE. Approximate finish time: 06:00 PM LIMITED SPOTS AVAILABLE: Limited to 10 Intermediate drivers maximum. RSVP will close on Thursday - 9 AM. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Members that do not confirm the terms of the COVID requirements will be removed from the RSVP list. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month Please RSVP on below calendar: 4 Link to comment Share on other sites More sharing options...
Craig Finlayson Posted December 6, 2020 Share Posted December 6, 2020 Can you add me to the waiting list? Just finished work and was a bit late getting online. Thanks 1 1 Link to comment Share on other sites More sharing options...
Mukundan Nair Posted December 6, 2020 Share Posted December 6, 2020 Hi Emmanuel Can You please put me on the waiting list. 2 1 Link to comment Share on other sites More sharing options...
Emmanuel Posted December 6, 2020 Author Share Posted December 6, 2020 Waiting list: 1. @Craig Finlayson 2. @Mukundan Nair 1 Link to comment Share on other sites More sharing options...
Emmanuel Posted December 6, 2020 Author Share Posted December 6, 2020 @Nizam Deen I’ll keep you signed in for now but I have to ask you, in order to confirm your attendance to this drive, to fix properly your front right wheel issue. It’s not normal (and not comfortable for the rest of the convoy) that you have a pop out every time, on the same tyre, with same air leak after every quick fix. Please check the rim measurements, replace it if needed, and let me know by Wednesday so that I know if I can allow you. Thank you for your understanding. 2 1 Link to comment Share on other sites More sharing options...
Emmanuel Posted December 6, 2020 Author Share Posted December 6, 2020 @Craig Finlayson since Nizam decided to sign out, I added you. Can you confirm? 1 Link to comment Share on other sites More sharing options...
Craig Finlayson Posted December 8, 2020 Share Posted December 8, 2020 On 12/7/2020 at 12:13 AM, Emmanuel said: @Craig Finlayson since Nizam decided to sign out, I added you. Can you confirm? Yes please that would be great. Thanks. 3 Link to comment Share on other sites More sharing options...
M.Seidam Posted December 9, 2020 Share Posted December 9, 2020 On 12/5/2020 at 10:26 PM, Emmanuel said: This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely. MUST READ AND TOTALLY AGREE: COVID19 Precautions MUST READ AND TOTALLY AGREE: BAN POST Two Way Radio Guidelines Every Off-roader brings his own radio, programmed to the frequencies described in below advice topic. We will not share spare radios or program your radio on the drive. If you need assistance in programming the radio, post a topic on the Carnity website with your questions and we will help you out. Make sure your radio is fully charged. It will be your only way of communication while driving. Before buying, please carefully read below advice so you are informed properly on which model / cost / shops... No radio = No drive. It is an essential tool and you should make sure you bring it on every drive and learn/practice how to use it. Drive Details Level: Intermediate and above When: 11 December 2020, Friday Meeting time: 2:00 PM (SHARP - Without any exceptions) Meeting Point: https://goo.gl/maps/qTpBjsXfXkCekFMo9 Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water, snacks (for yourself), face mask, rubber gloves, enthusiasm and willingness to learn. Please also make sure you have all the equipment required on board as an Intermediate. THIS IS A COMPRESSOR ONLY DRIVE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE. Approximate finish time: 06:00 PM LIMITED SPOTS AVAILABLE: Limited to 10 Intermediate drivers maximum. RSVP will close on Thursday - 9 AM. If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Members that do not confirm the terms of the COVID requirements will be removed from the RSVP list. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month Please RSVP on below calendar: Best of luck for the new intermediates , catching you soon 1 Link to comment Share on other sites More sharing options...
Heisem Posted December 10, 2020 Share Posted December 10, 2020 Hi @Emmanuel wont be able to join this afternoon drive. Wishing you guys amazing dunes 2 1 Link to comment Share on other sites More sharing options...
Alexander Alcala Posted December 10, 2020 Share Posted December 10, 2020 Dear friends, I have to drop from this drive. Please enjoy and I will see you next week. Cheers, 2 1 Link to comment Share on other sites More sharing options...
