shael Posted May 9, 2011 Report Share Posted May 9, 2011 when by battery was not charging i got it changed but still the battery is not charging so i get the alternator checked which seemed good now what Link to comment Share on other sites More sharing options...
chian Posted May 18, 2011 Report Share Posted May 18, 2011 Jump start the car and remove the battery and see if car is running then that means alternator is fine. Then you can doubt the big battery fuse in fuse box 100 Amp something. There is no other thing to fail than battery and alternator, if you change the battery then it seems alternator for sure. but 1% doubt goes to fuse. Link to comment Share on other sites More sharing options...
shael Posted June 7, 2011 Author Report Share Posted June 7, 2011 checked and done thanks Link to comment Share on other sites More sharing options...
