Morning Fewbie Plus Desert Drive - Murquab - Technical Terrain Transit - Part 3/3 - Dubai - 18 Jun 2022
GauravSoni
Dear Dune Surfers,
This drive is Part 3 of 3 Skill Drive Series in which we would be focusing on the skill of Navigating the Technical dunes!
Part 1 - Ridge Rider Republic – Al Qudra – 21 May 2022 - Completed!
Part 2 - Criss Cross Country  – Faqa - 28th May 2022 - Completed!
Part 3 -  Technical Terrain Transit - Its happening NOW !!!
The drives are for Fewbie Plus and above only as we believe at this level you are well aware of your car, your driving style in sync with your car for these drives to learn, challenge and improve albeit safely. Please watch out for the subsequent parts in coming weeks and join in as per your availability.
For the final Part of the Skill Drive Series ( Chapter 1) we will be Transiting through the "Technical Terrain" between Muraqaba and Qudra.  This drive is going to be slow paced drive as we would be navigating tight dune formations and finding the best path to get in and out. we would occasionally free up our engines going all out on some long range dunes for a breather!
We will be taking the shortest route from Murquab towards Qudra, which means we will be driving around Solar park area technical patches in safest way possible.
Drive Time is expected to be 3 hours .
We will aim to get out of the dunes by 8.45 am however be prepared for some adventure!
Technical drives are more demanding in terms of attention / steering and throttle control. This is the game of 2000!
Make sure you come with a full tank, Car in good conditions, recovery gear for this level (Radio, Flag, Deflator, Compressor, Kinetic rope and Soft shackles). Recovery points should be checked and in good conditions.
It is preferable for the cars to have a front bash plate (6mm or more) to keep the radiator protected, if not it is at your own risk to join.
General Info
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE:
Drive Details
Level:  Fewbie Plus and Above
When:  18 June 2022 , Saturday
Meeting time: 5.00 AM (SHARP - Without any exceptions).
Meeting Point: updated
Dropped pin
https://goo.gl/maps/spXZ1eStL6Fix7Nk8
Exit Point: Solar Park - Qudra.
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance and Bash Plates
What to bring along: Loads of water, snacks (for yourself), smiles, face mask, rubber gloves, enthusiasm and willingness to learn.
Approximate finish time:  9.00 AM or early
LIMITED SPOTS AVAILABLE:
  • Limited to 10 cars only. RSVP will close on Friday - 1 PM.
    • If the RSVP is full and you wish to join, please mention your name on the drive thread to add on the waiting list.
  • Latecomers will be returned back - without ANY EXCEPTIONS.
  • Members without RSVP will be returned back - without ANY EXCEPTIONS.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month.
PLEASE RSVP ON THE BELOW CALENDAR EVENT
  • Well Done (+2) 2
  • Gaurav changed the title to Morning Fewbie Plus Desert Drive - Murquab - Technical Terrain Transit - Part 3/3 - Dubai - 18 Jun 2022
1 hour ago, Senthil Kumar said:
@Gaurav Soni please confirm the start location, seems provided link is showing some where near Damac hills,
Meeting point updated: thanks @Senthil Kumar this has happened second time for a location in this area… 😳
These type of dunes that you bring one wheel on it and the rear still didn’t leave the previous one ( spider march ) . Love them a lot 🤣
  • Haha (+1) 2
  • Totally Agree (+2) 2
1 minute ago, Karthik Raptor said:
Maybe I have to trim the truck a bit 😅
You mean to shorten it 🤣.. kidding you will do good I bet
2 hours ago, Ale Vallecchi said:
@Gaurav Sonithat's one of the most technical areas, with some of the tightest dunes I have seen. Especially the beginning. Get ready for a lot of bouncing around 😅😎
That’s the plan ! Face the worst fears head on and be victorious! Of course we will have challenges on the way but mentally we will come out stronger!
  • Totally Agree (+2) 3
  • Well Done (+2) 2
