Morning Fewbie Plus Desert Drive - Fayah - Abu Dhabi - 21 Oct 2023
DRIVE DESCRIPTION
Welcome to Carnity off road club Fewbie Plus drive, meeting and ending at Fayah meeting point of the beautiful Abu Dhabi Desert, please ensure your off-road gear is as per your rank and you bring lots of enthusiasm with you.
Drive Details
Level:  Fewbie Plus and above
Meeting time: 6:30 AM (SHARP - Without any exceptions)
Meeting Point:  https://maps.app.goo.gl/acreM77zLxB2MRu76
If you approach the gate it will open automatically.
Approximate finish time: 10:30 AM
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 1 PM.
PLEASE RSVP ON THE CALENDAR
Dear @ahmad lootahWelcome to carnity.
Please note this drive is for Fewbie plus and above level and since you are new/ first timer to the club, you can join only a Newbie drive. Hence Please select one of the newbie drives , there are 2 drives happening tomorrow one is scenic and other is offroading desert drive in Abu dhabi.  ( currently you will be waitlisted since all the drives are posted on Monday 7pm, and depending on total convoy count and lead's decision the waited listed candidates gets confirmed or if someone drops from confirmed list the next person moves up, a person with zero drives gets preference over someone already having another confirmed drive)
IF you have any prior experience you can declare it to be considered for your promotion to Fewbie level, else you do minimum number of drives to level up yourself.
See you sooon in one of the drives!:)
Regards
Edited by DP1011
Thanks @DP1011 for the great overview. @ahmad lootah I have unfortunately had to remove your RSVP from this drive. We will look forward to welcoming you onto the higher level drives once you hold the correct grade for the level of drive. Please have a look at the following link to assist you navigate the structure. Please also reach out if you need more assistance.
I want to leave this here for easy reference tomorrow morning:
https://maps.app.goo.gl/XpCRDACquc4m5ZDs8
This is the ADNOC fuel station 18km to the meeting point. Note that it does not have an ADNOC Oasis shop, but rather a small shop/cafe that doesn't sell much. No Hot coffee for sure.
Dear desert Wanderers, @DP1011 @Mohit Gurnani @Ranjan Das @Rk ram @Deepak Eswar @Dodi Syahdar @Patrick van der Loo @Gertjan and @Looper please see below convoy order for tomorrow's adventures, we will be using Ch4 446-081
looking forward to seeing you all at the meeting point tomorrow morning
@ahmad lootah you can request a hire rank with evidence of previous drives, you request this in the same way on the forum in promotions
45 minutes ago, ahmad lootah said:
Dear @DP1011 thank you for you message , unfortunately i missed to check the level requirements during the registration, so as I understood now that i should join the newbie drive to qualify for this drive despite my actual driving experience ?
Dear @ahmad lootahwelcome to Carnity !
Every newjoiner (whatever the drive level and experience) will first need to do 1 Newbie level drive. Once that one is completed you can request a promotion to Fewbie level on below link:
Request Promotion
This is to ensure we can gauge your previous experience and make sure you are safe and looked after.
See you soon in the sand !
Request Promotion
@Frederic thanks for the clarification and appreciated as always
