Morning Fewbie Desert Drive - Faqa to Sweihan - Dubai - 12 Nov 2023
Frederic
DRIVE DESCRIPTION
Trying to make our way through Faqa, and heading towards Al Ajban. Expect a semi-technical drive :)
We request every member that joins this drive to go through the below information and strictly follow these guidelines, etiquette and responsibilities.
DRIVE DETAILS
Level:  Fewbie and above
When:  12 November 2023, Sunday
Meeting time:   07AM - Sharp (Without any exceptions)
Meeting Point:  https://maps.app.goo.gl/591afzyayHPUXmVWA
Approximate finish time:  11AM
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, Tow Rope, 2 Shackles and fire extinguisher.
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others in the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON BELOW CALENDAR
Dear Members
@Xavi Moyano@Andrei S@Abhilash Kottakkal@Shahid Mehmood@Haneef Thayyil@Rafey Hashmi@Dan S
Thanks for signing up !
I wanted to let you know that i've moved my meeting point just a bit further down at Faqa Truck Road itself, as this weekend there is an Dubai Baja Challenge which will mostlikely mean that many parts of Qudra and Faqa will be fenced off.
New meeting point:
See you all soon !
Dear Frederic @Frederic, I am coming from Abu Dhabi and I just wanted to confirm with you, if this ADNOC station is the closest one to the meeting point considering the fact that I will come from AD, I do not see any other one with low impact on travelling time.
https://maps.app.goo.gl/RkZXYH5GTrPqNuc87
I will be looking forward to your feedback, Many thanks!
If you are coming from Abu Dhabi i would assume taking the E11, followed by E14 is better. In that scenario you will have the Al Samha ADNOC on the E11.
Understood, thank you Frederic, I think I can also follow E20 up to the Nahil Adnoc right before coming from Lane 1821 between the farms up to the meeting point. I believe this one is closer
30 minutes ago, Dan S said:
@Fredericone small confirmation please, inside event description it is written When:  12 November 2023, Saturday
But I believe the actual ride will, be on 12.11.2023, Sunday, correct?
Oops yes sorry for the typo.
Just closed the convoy list.
As it's a small convoy, we will do the numbering tomorrow.
We will be using Channel 4 - 446.081 Mhz
See you soon !
