Morning Fewbie Desert Drive - Fayah - Abu Dhabi - 17 Dec 2023
Davie Chase
hey @Davie Chase, thanks for the drive today, was a really nice area and a fun drive.
Have checked the issue with the car and put in on scanner, thankfully it was all ok... the issue was due to some corrosion formed on the connectors of the battery...
Lesson learned, never let the guys at the staion spray the engine bay, and never let ur eyes off of them even if you specifically instructed them to just put some water on 1 specific area :)
thanks! and see you all soon.
It's been 24 hours and I'm still reliving the experience in my mind, that's when you know it was a classic @Davie Chasedrive!
Side slopes, climbs, technical dunes and most of all a lot of high speed fun.
@Emanuel excellent S/L with viper instincts for instantaneous reactions to Davie's shout outs.
@Imteeaz thank you for clean and simple support!
Learning from the drive:
1. 5PSI is the new black. Thanks to @Frederic. Although I'll start with 5.5PSI and let the air go up and then deflate to avoid a 'too low' situation.
2. Introduced the third gear in this drive, have been using 1st and second only on all earlier ones. Getting a grip of it during climbs and sidies. Helps maintain momentum.
3. Davie withholds the power to jinx a clean sheet.
4. Jimny's can be tugged by Rubicons on neutral (jk)
See you all next year :)
#JimnyPower
@DP1011 @Davie Chase @Varun Mehndiratta @Pacific @Mahmoud Taha
Many thanks for this drive gentlemen and for making it available for 2 convoys.
I had fun, met new colleagues and enjoyed the white amazing sands of Al Fayah.
Thank you for the rest of the convoy also, making it amazingly fun.
See you soon in the desert!!
  • Like (+1) 6
  • Thanks (+1) 2
