DP1011 Posted July 1, 2024 Share Posted July 1, 2024 Drive Plan : The drive will be testing the skills of handling small technical dunes that the desert of Lisaili offers and will require LOT of patience, right control of RPM , hence its termed - Technical Challenge . IF you are looking for a fast pace roller coaster drive, then this one is not for you . We will be offered with to deal with soft sand, with super tight patches and keeping appropriate distance will be another key requirement of this drive. Considering summer and rapidly increasing temperature levels, we will start the drive at Sharp 5.20 latest - hence please aim to be at meeting point at or before the time mentioned i.e 5:15am! MUST READ AND COMPLY Environmental Policy Offroad Flag Guideline Two Way Radio Guideline Off road Driving Etiquettes Emergency details for all off roaders Off Road Driving - Roles & Responsibilities Level: Fewbie plus and above When: 06 July Saturday Meeting time: 5.15 AM - Sharp Meeting Point: https://maps.app.goo.gl/taDoGGgPsdFbsuBR7 Approximate finish time: 8.45 am Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn. RECOMENDED OFF-ROAD GEAR: Tire deflator & Tire pressure gauge Compressor (MANDATORY) Walkie-talkie radio (MANDATORY) Off-road flag (MANDATORY) Shovel, Tow Rope & 2 Shackles First-aid kit Fire extinguisher LIMITED SPOTS AVAILABLE This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM. If the RSVP is full, you can add your name to the waitlist, once anyone drops, you will be moved to the RSVP list. RSVP will close a day prior to preparing a convoy list. Latecomers will be returned - Without any exceptions. Members without RSVP will be returned - Without any exceptions. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month. PLEASE RSVP ON THE CALENDAR Link to comment Share on other sites More sharing options...
DP1011 Posted July 5, 2024 Author Share Posted July 5, 2024 Happy Friday to all the Aspirants of Technical Challenge ( RSVP CLOSED) @Anoop Nair @Deepak Eswar @Rafey Hashmi @Shiju Raju @Mahesh_ @Brett Eicher @Andrew John Melvill @Amr A @christian Convoy order will be shared later during the day - hence Please accordingly update your RSVP if need be. Please note the meeting point : https://maps.app.goo.gl/kxATMQLQTUnu7JNy7 Most importantly The MEETING TIME : Deflated by or before 5.15 AM- Today's temperature was better in Mid 35s even at 9.30, so am hoping we will weather God in our favour tomorrow. WE WILL MOVE 5.20 LATEST and we aim to exit in about 3 hours time approx. We will start our drive with the famous Lisaili entry point with some brisk pace just before hitting the Technical patches, also encounter some vegetation as we continue to make our move towards chimney with some of the most challenging technical dunes on our way. Ensure all your gears are in place securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear. Looking forward to seeing you tomorrow morning ! DP . 3 1 Link to comment Share on other sites More sharing options...
DP1011 Posted July 5, 2024 Author Share Posted July 5, 2024 3 hours ago, DP1011 said: Happy Friday to all the Aspirants of Technical Challenge ( RSVP CLOSED) @Anoop Nair @Deepak Eswar @Rafey Hashmi @Shiju Raju @Mahesh_ @Brett Eicher @Andrew John Melvill @Amr A @christian Convoy order will be shared later during the day - hence Please accordingly update your RSVP if need be. Please note the meeting point : https://maps.app.goo.gl/kxATMQLQTUnu7JNy7 Most importantly The MEETING TIME : Deflated by or before 5.15 AM- Today's temperature was better in Mid 35s even at 9.30, so am hoping we will weather God in our favour tomorrow. WE WILL MOVE 5.20 LATEST and we aim to exit in about 3 hours time approx. We will start our drive with the famous Lisaili entry point with some brisk pace just before hitting the Technical patches, also encounter some vegetation as we continue to make our move towards chimney with some of the most challenging technical dunes on our way. Ensure all your gears are in place securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear. Looking forward to seeing you tomorrow morning ! DP . Hi all - Below convoy order ! See you deflated 5.15am ! - DEPENDING ON HOW THE MOVEMENT IS, WE WILL HAVE SOME SWAPS IN CONVOY POSITIONS 4 Link to comment Share on other sites More sharing options...
Rare Mahesh_ Posted July 6, 2024 Share Posted July 6, 2024 Hi all few pictures 2 Link to comment Share on other sites More sharing options...
Brett Eicher Posted July 6, 2024 Share Posted July 6, 2024 Thank you for the drive today @DP1011 Great way to spend the morning! 1 1 Link to comment Share on other sites More sharing options...
Andrew John Melvill Posted July 7, 2024 Share Posted July 7, 2024 Thanks @DP1011 for another drive that lived up to its title! Good technical terrain linked togeter by streches of "jungle". A good number to refusals and stucks as should be expected on a tech drive, some really soft sand tested the cars and drivers over and above the tight dunes. But lots of good humor and laughs along the way! 2 1 Link to comment Share on other sites More sharing options...
Deepak Eswar Posted July 8, 2024 Share Posted July 8, 2024 @DP1011The drive was excellent, and I enjoyed the morning. and also could learn/brush up on my technical skills. Though we faced some refusals, we managed to exit more or less on time. I look forward to joining your next technical drive, like the three-hour drive. Thank you. 1 1 Link to comment Share on other sites More sharing options...
