Ishak Posted April 6 Share Posted April 6 About a year ago, in May 2025, I joined @Looper Intermediate drive which started from Shuwaib. It was a great learning experience and a memorable journey across varied terrain. This time, we plan to approach the drive differently by starting from the Badayer side and progressing toward Shuwaib. With a group of maximum 8 cars, the intention is to enjoy a steady Intermediate-level drive, focusing on flow and control. The plan is to progress in the direction of Shuwaib, making the most of the terrain along the way. Depending on time, pace, and conditions, we will aim to finish near Shuwaib, with flexibility to exit earlier if needed. Safety, flow, and enjoyment will take priority over reaching a fixed endpoint. Please read, understand, and follow the guidelines, etiquette, and responsibilities below. MUST READ AND COMPLY Environmental Policy Offroad Flag Guideline Two Way Radio Guideline Off road Driving Etiquette's Emergency details for all off-roaders Off Road Driving - Roles & Responsibilities Convoy Off-road Drives - Safety protocol during emergency alert DRIVE DETAILS Level: Intermediate Meeting time: 06:30 AM (SHARP - Without any exceptions) Meeting Point: https://maps.app.goo.gl/SoS9NLRgvVSvJYtb8 Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water & snacks (for yourself), smiles, enthusiasm and a willingness to learn. Mandatory off-road gears: Newbie and above, Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, first-aid kit, fire extinguisher, Intermediate and above, Tow Rope and 2 soft Shackles. Note: Please ensure that all of your off-road gear is securely tied down with ratchet straps in the rear compartment of the vehicle. Bungy type tie downs are not suitable for tying down off-road gear. Approximate finish time: 09:00 - 09:30 AM P.S. Only join if you have a compressor to inflate your tires after the drive. LIMITED SPOTS AVAILABLE This drive is limited to 8 cars only. RSVP will close on Friday - 1 PM. If the RSVP is full, you can add your name to the waitlist, once anyone drops, you will be moved to the RSVP list. RSVP will close a day prior to preparing a convoy list. Latecomers will be returned back - Without any exceptions. Members without RSVP will be returned back - Without any exceptions. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month. Please RSVP on the calendar below: 1 Link to comment Share on other sites More sharing options...
Ishak Posted April 10 Author Share Posted April 10 Hello desert wanderers, @Abhishek Chikara @Glenn W @Alphin Aloor @Cha @Frans M Thank you for joining our drive tomorrow. Here is the initial convoy order We will use Carnity radio channel 8 See you tomorrow! 1 1 Link to comment Share on other sites More sharing options...
Abhishek Chikara Posted April 10 Share Posted April 10 (edited) @Ishak hope you're doing well. Since sand might be a bit wet, how much should I deflate my A/T Geolanders too? 12 psi or a bit higher - 13 to 14? Thanks Edited April 10 by Abhishek Chikara 1 Link to comment Share on other sites More sharing options...
Ishak Posted April 10 Author Share Posted April 10 41 minutes ago, Abhishek Chikara said: @Ishak hope you're doing well. Since sand might be a bit wet, how much should I deflate my A/T Geolanders too? 12 psi or a bit higher - 13 to 14? Thanks Hi @Abhishek Chikara, I am doing well thank you, hope the same on your side. That is good point to be aware of. After last week rain, the top layer may looks normal sand but 10 - 15 cm below may still hard and compacted. lets call it "Sand with hidden concrete". This condition may be good for high climb because it has natural base support like a concrete, but it is is tricky for sideload for when we will do ridges and sidies. So lets start with 14 - 16 psi for non beadlock, and 12 - 14 for beadlock. We wil adjsut later wen we have more refusal to a lower pressure. 1 Link to comment Share on other sites More sharing options...
Glenn W Posted April 10 Share Posted April 10 Sorry guys for the last minute dropout. I’m still actually at work, there has been quite a lot of delays today hence I’m still here. No way I’ll get back from Abu Dhabi in time for the drive so I’ll have to sit this one out … again ☹️ …. Enjoy!! 1 Link to comment Share on other sites More sharing options...
Ishak Posted April 11 Author Share Posted April 11 Hopefully next time soon @Glenn W Link to comment Share on other sites More sharing options...
Ishak Posted April 11 Author Share Posted April 11 @Abhishek Chikara @Alphin Aloor @Cha new meeting point https://maps.app.goo.gl/cJPMXDLRkfG4NdnT6?g_st=ic keep going straight from the previous meeting point then you will see round about Link to comment Share on other sites More sharing options...
Ishak Posted April 12 Author Share Posted April 12 Hi everyone, Thank you all for showing up for this drive. It was a great drive and felt really good to be back on the IM drive after quite a long time. The sand was a bit challenging with many cross tracks, so thank you for being cautious and steering down whenever needed. We managed to cross from Badayer to Shuwaib right on time, with enough room for play and proper break time. I hope you enjoyed it as much as I did. Thanks to @Frans M for being the second lead, polishing the track and maintaining perfect distance to react whenever needed. @Abhishek Chikara and @Alphin Aloor you both drove very well and it was clear you enjoyed the climbs. Up, up, and keep going! 😅. @Cha, thank you for the great support and for making sure everyone stayed on track. We returned as a complete team with no one missing, well done 🤣. We had a nice surprise when we reached the top of Iftar Bowl from the back side and while riding the ridge downhill, seeing Dr. @M.Seidam there watching us. Thank you once again for the support and the helpful rerouting. Looking forward to seeing you all on the next drive! 🤣🤣 1 1 Link to comment Share on other sites More sharing options...
Abhishek Chikara Posted April 13 Share Posted April 13 A bit late but thanks so much @Ishak for the wonderful and start to the weekend. Enjoyed it thoroughly - the second half in particular was amazing with clean dunes, beautiful ridges, and great momentum. Thanks again Thank you @Frans M, @Cha for the constant support throughout the drive. It was wonderful to see you @M.Seidam at Iftar Bowl, and here's hoping we get to see you at Nahel next weekend 3 Link to comment Share on other sites More sharing options...
Ishak Posted April 13 Author Share Posted April 13 Thank you @Abhishek Chikara, have you figured out with the ESC issue? Link to comment Share on other sites More sharing options...
