which tool required to replace rear trunk shocks ?
Normal thin screwdriver is enough.
Look at the base of shock and you will see small clip, pluck that grip out and shock absorber will come out. Then stick the new one just by pushing as it will automatically lock the grip once positioned properly. So after sticking it try to pull out and it should lock in its palce. If not try again.
