ac is not working
If AC gas topped up by road side Iranian guys, do it again with some reputed place. Tey will empty all gas and refill again and check for leaks with soap water.
Hope that will find the problem, Changing AC isnt the solution. Later you can fix the airline leak if any) or change the evaporator or drier or last is the compressor.
