dnoor Posted June 1, 2012 Report Share Posted June 1, 2012 i am looking for the very wired joint part and i dont even know what it is its called constant velocity joint what is this joint and what is its function? Link to comment Share on other sites More sharing options...
pardeep Posted June 29, 2012 Report Share Posted June 29, 2012 Constant-velocity joints which is also called CV joint allows the drive shaft to transmit power through different angles, at continues rotating speed, without an appreciable increase in friction or play. Link to comment Share on other sites More sharing options...
samesh Posted July 11, 2012 Report Share Posted July 11, 2012 Thats one hell off techy explanation Pardeep have given. Nice one. CV joint is covered under CV boot loaded with grease so that all the time they are rotated under lubricated atmosphere. With age CV boot tends to get torn and grease leaks out and that's where CV joint get damaged. Its a small metal joint behind ur front tire that connects to steering rod. Link to comment Share on other sites More sharing options...
