hrithik Posted July 29, 2012 Report Share Posted July 29, 2012 Hi All, I have a 2006 Pajero 3.8 Litre. After driving around 20 kms, the yellow light in the middle of the 4WD starts flashing and all other green lights gets off. This happens when i continously drive on a long way .When i switch off and switch on the engine, it comes back to normal. I normally drive in 2WD mode. The second issue is, when i change to 4WD mode, the upper green lights keep on blinking. I just had my 80,000 service done at Al-Habtoor, and as informed by one of the service guy, that's normal in pajero. Do any of you have got the same problem?? How wasit fixed?? Also needs advice on, after how many Kms i have to change the timing belt Please advice any good workshop for Pajero repairs in Abudhabi, as Al Habtoor is charging a lot for small things. Thanks in Advance.. Link to comment Share on other sites More sharing options...
nomanr Posted August 2, 2012 Report Share Posted August 2, 2012 For light blinking and flashing i think its a known issue and cost a leg and arm to fix it, thats why mItsubishi guys says it ok. damn japanese. lolol. Secondly i cant refer any garage in adbu dhabi as im from dubai, but im sure if you got to mussafah industrial area once and look around, you might find some good mitsubishi garage there. Do you have dynatrade in abu dhabi, thats my next best favorite place since i ditched habtoor....! Link to comment Share on other sites More sharing options...
hrithik Posted August 6, 2012 Author Report Share Posted August 6, 2012 Hi, Diff light problem is fixed. I went to Al-habtoor and the've charged me 800 Dhs. This was a problem with an electronic swith which is located on front right-hand side inside the bonnet. As per them, this may have caused as the 4WD was not used regularly. There is Dynatrade in Abudhabi as well. Is that a good place where i can change the timing belt of pajero. In Al-habtoor, timing belt change costs around 8000 AED. Thanks.. Link to comment Share on other sites More sharing options...
razi55 Posted December 12, 2016 Report Share Posted December 12, 2016 HI, I am suffering with the same problem about middle diff light, starts blinking after 30 kms and goes off when I switch the jeep off and re-start. As advised by mechanics, the transfer case oil has been replaced but no change. They are saying to change the Transfer case......OMG, how lethal are they..... But some say, its just an electrical fault. I don't want to spend even 800 on it that you spent. Please guide. Regards, Razi 0506554313 1 Link to comment Share on other sites More sharing options...
