Armada Rear Lights
Has anyone experience with fitting on the Armada the rear tailgate lights of the Infinity QX56?
Do they fit?
I find them nicer looking the the Armada Tailgate and breaking lights.
If they fit, does anyone know which scrapyard in Sharjah might sell parts from the QX56.?
Thanks in advance
More than likely it will and it should fit, im 90% sure. As they both share same platform and same US build. It must have had just cosmetic shape change for different league and base bracket and screw positions must be absolutely same.
You can check many scrap yard in back side of Troy university in sharjah. If you coming from sahara center mall from Dubai to Sharjah, then from Troy University signal take right and all scrapyard are lined up on right side.
