what else can i change when changing the timing belt
  • 3 weeks later...
i suggest just change what you have to that is the timing belt as of now and also check the baring if it needs changing. dont over think and if you tell your mechanic that you want to change other things then they may forcefully change other parts. let the mechanic see your car and see what he suggests.
  • 6 months later...
  • 4 weeks later...
  • 1 month later...
  • 1 month later...
  • 3 weeks later...
