mukeshs
What is making my golf vibrate and what damage its causing?
If the vibration is constant and very low will this till do harm to the engine or the car in general? after wheel alignment and changing the axels there is still very slight vibration that i only feel when the car is below 60.
Is this damaging the car?
Go to a garage with suitable equipment and check the wheel alignment. This situation will only get worse if you don't fix the problem. It will cause you driving problems and you will jeopardize your personal safety and the safety of the other drivers.
Hi
You have a problem with one of your inner CV joins and require replacement!
for the 2008 shacking in start either using wrong oil grade (less than 10W-40) or aftermarket oil filter (without check valve)would give you that shacks and metal knocking.
