unas Posted June 28, 2011 Report Share Posted June 28, 2011 when i switch on my 2005 BLS the wiper starts with it and dose not stop till i switch off the car. how can i stop this Link to comment Share on other sites More sharing options...
ketan Posted July 1, 2011 Report Share Posted July 1, 2011 Sounds like wiper relay is freaking and its time to change that. Its easy and cheap fix. Cadillac BLS Engine Compartment Relay Center is located next to the battery on the driver’s side of the engine. The following schematic will guide you understand your Cadillac Engine Compartment Relay/Fuse. 1. Secondary air injection 2. Fan control relay 3. Auxiliary water pump 4. Windshield wiper motor 5. A/C compressor relay 6. Fan control relay 7. Fan control relay 8. Fuse 50 9. Fan control relay 10. Engine controls power relay 15. Fuse 40 (A), Fuse 52( 17. Coolant fan test connector fan control 18. Fuse 42 (A). Fuse 49 ( 19. Fan control relay 20. Fuel pump relay 29. Fuse 43 Link to comment Share on other sites More sharing options...
