My honda jazz 2004 O2 sensor fault
my honda jazz 2004 oxygen sensor bank 1 fault appear after wash the engine.
so now fuel consumption too high and cold start engine not accelerate quickly some time. when scan the car that time i got fault code P0132
PLZ give any contact in uae honda parts without dealer  i'm looking oxygen sensor bank 1 for my honda jazz 2004 0564679275 rohan
The fault occurred when you washed the engine? It's possible that the sensor is ok and you just have water in the plug causing a short. The first thing I would try is disconnect the plug, check for signs of corrosion on the pins, spray some WD40 into both sides and reconnect it. If the EML is still on, reset it and go for a drive and check.
Worth looking at, could save you a few Dirhams.
Have you tried the sharjah BM road spare part shops selling OEM at half price than dealers. Like Divya, Dhanya, Majelan, Hamadi, Sendabad etc.
https://www.google.ae/maps/@25.3201066,55.401727,18.31z?hl=en
If you are not looking for new one, then you can try the japanese car scrapyard behind macro emirates in sharjah
https://www.google.ae/maps/place/%D8%B3%D9%85%D8%A7%D8%A1+%D8%A7%D9%84%D8%AE%D8%A7%D9%86+%D9%84%D9%84%D8%AA%D8%AC%D8%A7%D8%B1%D8%A9%E2%80%AD/@25.3149408,55.4153735,17z/data=!4m7!1m4!3m3!1s0x3e5f5952bd059139:0xde97af767d23e7c7!2sMacro+Emirates!3b1!3m1!1s0x0000000000000000:0x382bc43ab1515e73?hl=en
