engine oil is going down then the level it should be in
warzi
If you also see excessive smoke behind exhaust then that means piston rings are leaking the oil in engine fire area and getting burnt. You need to change to new piston rings so that it seals well.
If your coolant turned milky substance then that means your engine head gasket is leaking engine oil in coolant compartment. With this you must experience loss of power too if head gasket doesnt seal properly 100%.
