Coolant Turning Greenish Brown
Sidshk
Hi
While changing Engine Timing belt mechanic found my coolant has turned into sort of greenish brown color, Any guesses the reason for it ? should i be worried ?
Note
I have changed my radiator recently and topped it with Mitsubishi original coolant
If coolant has turned greenish brownish inside the expansion bottle, then its fine. Clean the coolant bottle and refill. I am facing same in my ancient Pajero.
If coolant inside the radiator turned brownish, then it's a concern. Please confirm.
remove the thermostate then flush the system and then put a new thermostate and fill it again with toyota pink coolant bleed the system and have fun...
Edited by shadow79
more info
Its from inside the Radiator
Recently changed thermostat and Radiator  , its only 3 months old
If previously bleeding is not done by removing thermostat then saleem might be right, as engine jacket hold lot of coolant and the new and old coolant must have got mixed.
If you have bleed it before, then double check if its brownish or whitish? Has any sticky feel? Pungent smell?
No Its not sticky and doesn't have  Pungent smell , its just changed color
Brownish like Mountain Dew color
