Atif Posted December 5, 2020 Share Posted December 5, 2020 My Prado is is around 2.5 ton and comes with a bottle type jack. Do I need to have a floor type jack and does it have to be over 2 ton rating? I notice that the 2 ton floor jack is advertised most frequently and is also compact compared to the 3 ton one. In addition, as I don’t intend to lift the whole car but rather a portion of it, is the 2 ton one sufficient or is it unsafe? Await good advice! 4 Link to comment Share on other sites More sharing options...
Popular Post Frederic Posted December 5, 2020 Popular Post Share Posted December 5, 2020 If you intend to lift the vehicle in the desert, you'll need a floor Jack, as a bottle jack is not stable enough unless you weld it on a kind of platform. When buying a 2T floorjack go for the JZX brand available in Dragon Mart or the YATO brand from Speedex. You will only be lifting a portion of the car so a 2ton jack is sufficient. A 3ton is of course better and more stable but extremely heavy to take in your car and carry it around in the dunes. 8 1 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Rahimdad Posted December 5, 2020 Share Posted December 5, 2020 As @Frederic mentioned in the desert the bottle jack is very narrow and does not give a good base, very unstable. Thus a floor jack of 2 tonnes should be sufficient. You are not going to lift the complete 2.5 tonnes at any given time. But make sure you're on as flat a surface in the desert before jacking the car and get a jack board as your base. 3 1 2 Link to comment Share on other sites More sharing options...
Anish S Posted December 7, 2020 Share Posted December 7, 2020 On 12/5/2020 at 11:52 AM, Frederic said: If you intend to lift the vehicle in the desert, you'll need a floor Jack, as a bottle jack is not stable enough unless you weld it on a kind of platform. When buying a 2T floorjack go for the JZX brand available in Dragon Mart or the YATO brand from Speedex. You will only be lifting a portion of the car so a 2ton jack is sufficient. A 3ton is of course better and more stable but extremely heavy to take in your car and carry it around in the dunes. The JZX 2T floor jack is out of stock, i went to DM today 🙁 3 Link to comment Share on other sites More sharing options...
Gaurav Posted December 7, 2020 Share Posted December 7, 2020 1 hour ago, Anish S said: The JZX 2T floor jack is out of stock, i went to DM today 🙁 You can try other similar brand as far as they look and feel sturdy and heavy enough, then 2 ton jack is fine. Stay away from the flimsy ones. JZX jack is out of stock from sometime now, I guess due to logistics lag after covid lockdown. It's totally understandable. 5 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
M.Seidam Posted December 7, 2020 Share Posted December 7, 2020 (edited) 3 hours ago, Anish S said: The JZX 2T floor jack is out of stock, i went to DM today 🙁 The YATO brand in speedex had the last one few days back too ! I will see if I can order it on line though these items I prefer to buy them on the spot in order to avoid inconvenience should it occur! Edited December 7, 2020 by Mohamed Seidam 2 Link to comment Share on other sites More sharing options...
M.Seidam Posted December 7, 2020 Share Posted December 7, 2020 On 12/5/2020 at 11:09 AM, Atif said: My Prado is is around 2.5 ton and comes with a bottle type jack. Do I need to have a floor type jack and does it have to be over 2 ton rating? I notice that the 2 ton floor jack is advertised most frequently and is also compact compared to the 3 ton one. In addition, as I don’t intend to lift the whole car but rather a portion of it, is the 2 ton one sufficient or is it unsafe? Await good advice! @Atif I will check in speedex tomorrow morning as I am free , I will notify you if I find something , same for @Anish S . My cell is +971554045278 please give me a msg so I can let you know if interested cheers 2 Link to comment Share on other sites More sharing options...
dune jockey Posted December 8, 2020 Share Posted December 8, 2020 (edited) 3 T jack is heavier but makes lifting extremely easy once you have it in right position. As everyone mentioned the downside is its heavy to carry around Speedex has it available online (Yato Brand 2T) https://www.speedextools.com/jacks/586-low-profile-service-jack-2-ton-101720.html?__cf_chl_jschl_tk__=329806162e4776f210dc0544d520d8a0077b86ae-1607396370-0-AfsX75GG1Qgms1NeT2sfwLDX4h2vxcoYdB1g8XEGlaTvjV0knIHZqPxYMJB3EC4Pncv_QRGBs3xytkPNJB3UhY7lLGXfrkVigtSjG9hZXvshX1WZwM1BtQlTZqPMKIzfD7mh2mqN7nbF6AtxTNjx2kEPa6DRUGpPIP2Kav4g0EkH8r_UgoYrgfDOcvWy7fIHTLvGcZn-Qyw0f9_tw6scNmegCqMASf9KbRGBOf3vOluAi81a99ARAQlCYOtAWVlgHKqm6kMH3CdUSZSdGSJFXMs5i3LMz7Ec4yiYtHVJ6opJra8mhGvTEy0MDb6icvGV6eM1fTrt-hFdO6HZAbkufeDSD0eTqHVIaFOzrXS2_ZuKg_ngXE_mnCojJoqHLRq-RA Edited December 8, 2020 by Chaitanya D 2 1 Link to comment Share on other sites More sharing options...
Frederic Posted December 8, 2020 Share Posted December 8, 2020 Try Sedana trading or have a walk around in Al quoz or Sharjah Industrial where they have the automotive tools shops. 3 2 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Rizwanm2 Posted December 8, 2020 Share Posted December 8, 2020 (edited) when browsing just came across this one. not sure how good it is, but seems it has large flat surface at the bottom and could be fairly easy to operate as well. https://www.amazon.ae/Generic-Electric-Hydraulic-Impact-Wrench/dp/B07YDY3C7W/ref=pd_sbs_263_10?_encoding=UTF8&pd_rd_i=B07YDY3C7W&pd_rd_r=ef80e1fe-5477-4ff5-8af1-72170cd316ff&pd_rd_w=cjdMI&pd_rd_wg=7Szr4&pf_rd_p=eeb01fd4-5df5-4ddf-ada4-f6927bf8cf3c&pf_rd_r=361DR2Q4JH05VX2BM2N0&psc=1&refRID=361DR2Q4JH05VX2BM2N0 Edited December 8, 2020 by Rizwanm2 2 1 Link to comment Share on other sites More sharing options...
