Morning Fewbie Desert Drive - Murqab - Dubai - 1 Oct 2021
Islam Soliman
General Info
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through below information and and strictly follow these guidelines in order not to jeopardize someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE:
Drive details
Level:  Fewbie and Above
When: 1 Oct 2021, Friday.
Meeting time: 06:00 AM SHARP
Meeting Point:  24°49'16.3"N 55°34'35.3"E
https://goo.gl/maps/cTtRVwd2Hqy6NnX87
What to bring along: Loads of water, snacks (for yourself), face mask, rubber gloves, enthusiasm and willingness to learn.
Approximate finish time: 10:00 AM
End Point:
THIS IS A COMPRESSOR ONLY DRIVE. WE WILL  ENDING THE DRIVE A POINT, WHICH IS NOT CLOSE TO AN AIR LINE. IF YOU DO NOT HAVE A COMPRESSOR, PLEASE DO NOT SIGN UP FOR THIS DRIVE. IF YOU ARRIVE AND HAVE NO COMPRESSOR YOU WILL NOT BE ALLOWED TO JOIN THE DRIVE.
LIMITED SPOTS AVAILABLE:
  • Limited to 10 cars only. RSVP will close on Thursday - 3:00pm
RSVP Below:
thanks @Rsjiv Samuel for your interest in joining this drive. However unfortunately I will have to remove your RSVP as this is a Fewbie drive and you are still on Newbie level.
Looking forward for welcoming you to any of the drives in the future once the min required level is met.
if you believe you have met the min requirements for Fewbie from number of drives and required gear, pls submit the request for promotion with all details following the below guidelines and if your promotion is approved by Thursday you can then RSVP back in.
Dear, @Joji varghese @Serafino @Marwan Haddad @Alphin Aloor @Jeandre Bezuidenhout @Rsjiv Samuel
Pre-drive details below:
1- Weather is getting better and hopefully we will enjoy nice early morning breeze for at least the 1st hour or so. Please be on time and bring all your passion for off-roading and pull as much as you can of yourself out of bed.
2- Be at the meeting point by 6:00am (or before) and be ready to move max by 6:15am (deflated, flag erected, 4H on, radio on and set, airbags/traction/abs all set....)
3- Please ensure your programable radio is on, fully charged and set to Channel 3
4-Briefing will be done on on the sand before we start moving
5- please ensure you come with a full tank (as much as possible) in addition to all necessary gear for this drive level
Meeting Point: https://goo.gl/maps/cTtRVwd2Hqy6NnX87
See you all on the sand 😎
Convoy order:
Dear  @Max Beloenko, I just noticed you RSVPed to this drive. Unfortunately I will have to remove your RSVP as this is a Fewbie drive and Carnity records still sows you on Newbie level.
Once you complete the min requirements for Fewbie from number of drives and required gear, pls submit the request for promotion with all details following the below guidelines. Hope the below helps and looking forward for driving with you soon.
There are a couple of Newbie drives for this weekend that I can see have open slots. Please ping the drive lead and if agreed you can RSVP and enjoy one of these drive tomorrow.
