Kailas Posted January 8, 2023 Share Posted January 8, 2023 Let's aim to cross the Liwa Crescent from one side to another. To experience the magic of Rub’ al Khali (Empty Quarter) the largest uninterrupted desert on Earth! The Liwa Crossing through Empty Quarter offers a chance to witness nature in its purest form and in itself is a transcendent experience. However, traveling through the largest desert in the world is not something that should be taken lightly. It will be a 150 - 200 km off-road drive covered within 1.5 days through amazing breathtaking views and the enormous size of dunes on earth. What you will find here: Tallest sand dunes (200 - 300 meters) Steepest incline and drops Longest side sloping Broad ridge riding Faster heartbeat Sweaty hands Mandatory rules for Liwa Crossing (exceptional) drive. Considering its seriousness to keep you and your vehicle safe, these strict rules will be applied to all. For Fewbie Plus level you must have driven at least 2 Fewbie Plus drives with Carnity in the last 2 months. If you are newly promoted Fewbie Plus (less than 2 drives at Fewbie Plus level), then select Fewbie drive. If you were away on a long break (more than 2 months), then select Fewbie drive. It is highly recommended to drive alone, as it's a very serious and demanding drive to stay focused at all times. Maximum of one passenger allowed - No exceptions and trip lead will send you back. Make sure that passenger has no fear of heights, motion sickness and have been to full-day off-road drives before. As once we enter the desert, the only way out is from the other side, without any early exits for 100-150 kms. Everything in your car should be strapped and secured - All vehicles will be checked by the trip lead. Drive Preparation: Your car should be in 100% pristine working condition, so double or triple check everything. Full-size spare tire with a lug wrench to match your wheel nut size and its depth. For aftermarket rims - Your lug wrench also needs to match the wheel nut depth. As it's a long full-day drive, so catch up with enough sleep in advance. 5-10 liter of water per person. Snacks for breakfast, lunch, dinner and next day breakfast. Keep your car as light as possible by packing what is truly essential. Fully charged radio with spare battery and all other required off-road gears. Gas tank and required number of jerry cans should be full upon arrival. Last petrol station is ADNOC Khanoor (832): https://goo.gl/maps/FSUzbzURjQRGvFVN9 We request every member that joins this drive to go through the below information and strictly follow these guidelines, etiquettes and responsibilities. MUST READ AND COMPLY Offroad Flag Guideline Two Way Radio Guideline Off road Driving Etiquette's Emergency details for all off-roaders Off Road Driving - Roles & Responsibilities Drive Details Level: Fewbie Plus and above When: 21 Jan 2023, Saturday Starting time: 7:00 AM (SHARP - Without any exceptions) Starting Point: https://goo.gl/maps/gzyx4wRN5HBA4fdp8 You can come early and camp at the same starting point if you like. Last Fuel Station: https://goo.gl/maps/FSUzbzURjQRGvFVN9 ADNOC Khanoor (832) Fuel requirement: 6 Cyl cars = 100 Liter (Minimum) - 120 Liter (for more fuel-guzzling cars) 8 Cyl cars = 120 Liter (Minimum) - 140 Liter (for more fuel-guzzling cars) Carry an additional required number of jerry cans based on your car fuel tank capacity. Lunch Break: 1 Hour in between with a couple of short breaks (if needed). Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance. What to bring along: Loads of water, lunch, snacks, face mask, enthusiasm and willingness to learn. Approximate finish time: 12:00 PM, 22 Jan 2022, Sunday LIMITED SPOTS AVAILABLE: Limited to 10 Fewbie Plus and above drivers Latecomers will be returned back - without ANY EXCEPTIONS. Members without RSVP will be returned back - without ANY EXCEPTIONS. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month. Please RSVP on Below Calendar: 3 1 Link to comment Share on other sites More sharing options...
Kailas Posted January 12, 2023 Author Share Posted January 12, 2023 Dear @rohit kumar As per the Carnity drive record, you are a newbie. This drive is a fewbie plus level drive; hence can only add fewbie plus and above ranks only. 1 Link to comment Share on other sites More sharing options...
Harshal Posted January 13, 2023 Share Posted January 13, 2023 (edited) Wanted to know if jerry cans are mandatory? On a full tank I can go just above 600km. I'll refill at the gas station before the drive, thanks. Edited January 13, 2023 by Harshal Link to comment Share on other sites More sharing options...
Frederic Posted January 13, 2023 Share Posted January 13, 2023 13 minutes ago, Harshal said: Wanted to know if jerry cans are mandatory? On a full tank I can go just above 600km. I'll refill at the gas station before the drive, thanks. 600km off-road ? Fuel requirement is mentioned here: Fuel requirement: 6 Cyl cars = 100 Liter (Minimum) - 120 Liter (for more fuel-guzzling cars) 8 Cyl cars = 120 Liter (Minimum) - 140 Liter (for more fuel-guzzling cars) Carry an additional required number of jerry cans based on your car fuel tank capacity. As you have a V8 you will need to have a minimum of 120l of petrol (combination of gas tank + jerry cans). This is mandatory without exceptions. Of course if your main tank is already 120 liters then you are good. 1 "Go as far as you can see; once you get there, you'll be able to see further." Link to comment Share on other sites More sharing options...
Harshal Posted January 13, 2023 Share Posted January 13, 2023 5 minutes ago, Frederic said: 600km off-road ? Fuel requirement is mentioned here: Fuel requirement: 6 Cyl cars = 100 Liter (Minimum) - 120 Liter (for more fuel-guzzling cars) 8 Cyl cars = 120 Liter (Minimum) - 140 Liter (for more fuel-guzzling cars) Carry an additional required number of jerry cans based on your car fuel tank capacity. As you have a V8 you will need to have a minimum of 120l of petrol (combination of gas tank + jerry cans). This is mandatory without exceptions. Of course if your main tank is already 120 liters then you are good. Close to 600km on road, not sure about offroad lol, the tank capacity is about 144l so I'll be fine. Thanks. 2 Link to comment Share on other sites More sharing options...
Jessica Lambert Posted January 17, 2023 Share Posted January 17, 2023 I am very disappointed that I will no longer be able to make it. I’ve been looking forward to this for a year. No thanks to QIC, the worst insurance ever, who have taken 3 weeks to issue an LPO for an accident where someone hit me in the rain in DECEMBER. Have fun guys, takes LOTS of pics for me 1 2 Link to comment Share on other sites More sharing options...
Imran Asghar Posted January 19, 2023 Share Posted January 19, 2023 (edited) Morning all I finished stress testing my roof mounted 360 cam ready for liwa 💥 Here's a short tame sample: (play in 4k in settings) Edited January 19, 2023 by imranaasghar81 5 Link to comment Share on other sites More sharing options...
Tareq Al Turq Posted January 19, 2023 Share Posted January 19, 2023 Dear @Kailas thank you very mu h for adding me. Unfortunately I am not able to make this drive for family commitments. I hope all of you enjoy this drive and be safe. Regards 2 Link to comment Share on other sites More sharing options...
Beide Worku Posted January 20, 2023 Share Posted January 20, 2023 Hi @Kailas two weeks in a garage and I still didn’t manage to get my car back yet. I’m still holding out hope but looking less likely with every passing hour. I see there’s no one on the WL so I won’t leave yet but wanted to give you heads up in case I don’t make it. I was really looking forward to this and miracles do happen but in case this time it doesn’t, you guys have fun! 2 Link to comment Share on other sites More sharing options...
Imran Asghar Posted January 20, 2023 Share Posted January 20, 2023 Anyone planning to get there today evening and camp? Link to comment Share on other sites More sharing options...
