Restoration of Headlights
well it takes maybe less then 2 h. u have 4 stage sanding pads.... with first 3 do not do circular moves..go straight and up an down... u can feel under fingers rougher pieces of headlight... about 20-25 min of first one... second stage same moves about 10-15 min.. 3rd stage add water with soup to headlight together with that liquid that came in boxand rub 10 min same moves... last stage only soup and blue pad for about 10 min in circular moves.... dont forget to clean head light after every stage !.... when done with that spray that liquid that came and wait for some time.... while waiting clean pads and take 3 pads on top of each other an put them in cotton cloth.... clean headlights and apply polishing substance to whole headlight.. let it dry for 2-3 min and spray little of soapy water..... and start rubbing.....make sure u spray soapy water .... clean and do again until the are looking almost perfect... edges will take more attention in every stage.... dont damage paint of your car... when is done an no more ugly yellowish thing on headlight clean headlight and remove protective tape... clean all leftovers of polishing paste and apply uv protection coat that comes in boxset .... it takes time, patience and strong will to do itm but more u give more u get and its definitely cheaper than taking it to workshop for them to do it. Do not use polishing untill u are done with sanding.... only spec. liquid and soapy water !!!Good luck with work Dilshad
