Windscreen Washer Fluid Light is ON
humsafar
last weekend I was Driving over the Sand Dunes with lot of Bumps due to zillion previous tracks, and my car was jolting harshly, then all of sudden the Washer Fluid warning light came on,
After the Drive, I checked and found that the Fluid was at around 1/2 level, still i filled it to maximum, but the light did not switched off. I tried to hit the bottle to replicate the jerks and jolts it received during the drive, still no result, then I took out the main Switch/Plug from the bottle, remove the negative battery terminal and let it sit there for half an hour, then I plugged these back again, but still the light is on.
Can any one suggest any solution ?
  • 2 months later...
  • 1 month later...
Were you able to get the answer for your question yet?
If not, is there a reset / select button for the windshield fluid indicator? It is usually on a controller where you just need to click the "select" and it should reset.
