neetash Posted June 27, 2011 Share Posted June 27, 2011 what is the procedure of changing the break pads? thanks Link to comment Share on other sites More sharing options...
adnanJ Posted July 1, 2011 Share Posted July 1, 2011 Here are the steps to change the pads on a Mercedes C class. 1. Remove cap from brake fluid reservoir. 2. Remove tire. 3. You will need to remove the brake sensor and 2 pins. 4. Remove the star bolt holding the sensor. Remove the sensor. 5. Tap out the 2 pins with a screwdriver. You can also press on the metal clip that is holding them in. 6. Pull the 2 pins from the back side. 7. Pull/pry out the outside pad first. 8. Once pad is removed compress the piston all the way back into the caliper. 9. Pull/pry out the inside pad second. 10. You will now need to compress the inside piston as well. First, block the outside piston from coming back out. I used the bolt from my tire and it fit nicely between the rotor and the piston. 11. Now that both pistons are compressed, put the rear pad in first. 12. Put the outside pad in second. 13. Place the metal clip back and put the pins back in. 14. Replace the sensor wire/bolt. 15. Put wheel back on. **NOTE** After both brakes have been changed, replace the reservoir cap. Now, pump the brakes a few times to take up the slack in the system. Link to comment Share on other sites More sharing options...
