kery Posted August 24, 2011 Report Share Posted August 24, 2011 i was trying to replace the oil pan gasket and so i got the screws out but oil pan will not drop. Help? Link to comment Share on other sites More sharing options...
kumar Posted August 26, 2011 Report Share Posted August 26, 2011 Oil pan is usually vacuum sealed with gasket nicely stuck with it. Open the top engine oil pouring cap/screw and lower engine oil drain bolt. And then you have to tap a bit from all sides to lower the pan. Make sure you have removed all the screws.....! Link to comment Share on other sites More sharing options...
