Volkswagen Maintenance Procedures - Common Additional Servic
Volkswagen Maintenance Procedures - Common Additional Services
Volkswagen Air Filter Replacement
The air filter accumulates dust and debris and should be replaced to protect the engine and maximize fuel economy. For optimal engine performance and longevity, replace every 1 year or 25,000 kms.
Volkswagen Automatic Transmission Fluid Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. It should be replaced every 2 years or 50,000 kms.
Volkswagen Automatic Transmission Fluid/Filter Change
Automatic transmission fluid becomes heat fatigued and accumulates moisture over time which can lead to automatic transmission damage if not serviced regularly. The filter should be replaced at this time a well. This service should be performed every 2 years or 50,000 kms.
Volkswagen Cabin Air Filter Replacement
Over time the Cabin Filter(s) will accumulate dirt, pollen and debris which can leak in to the passenger compartment if left unchecked. They should be replaced every year or 25,000 kms.
Volkswagen Differential Fluid Replacement - Front
Differential fluid breaks down and becomes contaminated with moisture over time and can lead to differential damage from a lack of proper lubrication. It should be replaced every 2 years or 50,000 kms.
Volkswagen Drive Belt(s) Replacement
Drive belts crack and become glazed over time and can squeak or even break. They should be replaced every 70,000 kms.
Volkswagen Fuel Filter Change
The Fuel Filter becomes restricted as it accumulates debris from filtering the fuel which, can lead to performance problems and early fuel pump failure. It should be replaced at the mileage interval recommended by the vehicle manufacturer.
Volkswagen Rotate Tires
It is important to rotate the tires from front to rear every 8000-12000 kms so that they wear evenly. This may not be possible on some vehicles because of directional tread design or rim size differences.
Volkswagen Spark Plug Replacement
Spark Plug terminals wear down over time and can lead to engine misfires and increased exhaust emissions. Replace according to the vehicle manufacturers recommended replacement interval.
  • Carnity unpinned this topic
