fardin Posted July 13, 2014 Report Share Posted July 13, 2014 How do I test if I need a new fuel pump in my car? Link to comment Share on other sites More sharing options...
alikhan Posted July 21, 2014 Report Share Posted July 21, 2014 very good question asked. I know the follwing things. If younotice the following things in your car, that you result into new fuel pump. 1. If the engine of the car is sputtering when you drive on high speed, it mean the fuel pump is damaged. 2. If you notice the you are losing poweron the vehicle whenever you are accelerating more, if means the fuel pump function is failing. 3. Sometimes, the engine will not start Link to comment Share on other sites More sharing options...
fardin Posted August 20, 2014 Author Report Share Posted August 20, 2014 Thanks brother. After reading the post, i think my fuel pump is still fine and there is no such issue with the fuel pump. Link to comment Share on other sites More sharing options...
