horn sound low
first test the horn itself and to do that you should run a jumper wire to the power connector on the horn,
to the positive battery terminal.
When you touch the battery terminal, the horn should sound loud.
If the horn is sounding good, the problem is with either the switch in the steering wheel, or in the horn relay and if not then the horn has to be changed
