Arish Ehsan Posted November 23, 2016 Share Posted November 23, 2016 I have a Range Rover Sports Supercharged 2010 model. Of late, I notice quite an irritating vibration on steering wheel and the body. The vibration is not constant but its intermittent. So also is the intensity. It is not tyre, wheel alignment etc issue as I have changed all 4 tyres and realigned them. The service center which normally does its repair and servicing was unable to exactly pin point the cause. Any ideas? Link to comment Share on other sites More sharing options...
Rahimdad Posted November 24, 2016 Share Posted November 24, 2016 I have a mechanic who has worked on al land Rovers only and knows them thoroughly inside out. his name is Aqil, you can call him on 055 899 0092. He is currently working until 5:30 pm in Sharjah, so he can tell you where to meet him is Sharjah and what time. He should be able to pin point where the vibration is coming from and can also source parts for you if necessary. Hope this helps. Link to comment Share on other sites More sharing options...
brandan Posted November 24, 2016 Share Posted November 24, 2016 If it's not tires then more than likely it is from drive shaft or the u joint. Is it having a wobbly feel when it starts? Is it always above 100 it comes for sure? Link to comment Share on other sites More sharing options...
Arish Ehsan Posted November 24, 2016 Author Share Posted November 24, 2016 (edited) It comes up erratically. Sometimes at lower speed, sometimes at higher speed. When the vibration is there, it can be felt not only on the steering but also on the seats. There is no vibration when the car is not moving. Edited November 24, 2016 by Arish Ehsan Link to comment Share on other sites More sharing options...
brandan Posted November 24, 2016 Share Posted November 24, 2016 2 hours ago, Arish Ehsan said: It comes up erratically. Sometimes at lower speed, sometimes at higher speed. When the vibration is there, it can be felt not only on the steering but also on the seats. There is no vibration when the car is not moving. Sounds like a driveshaft, place on lift in petrol station and ask them to check shaft for any loose-play. Link to comment Share on other sites More sharing options...
Allstar Posted November 24, 2016 Share Posted November 24, 2016 May be the drive shaft just need a proper greasing, as it comes randomly so no permanent failure yet but signs of one showing now. Link to comment Share on other sites More sharing options...
