Gaurav Posted May 31, 2017 Report Share Posted May 31, 2017 I really doubt on this as if setting is provided by car manufacturer then it is supposed to be use, irrespective of its duration unless stated in owners manual, Like launch control in GTR. I had Lexus GS430 that comes with similar mode and all the time I was driving on comf mode and only 10% occasionally on sport when I like to try high speed cornering. Also agree with desertdude that suspension air ballon (rubber consumable item) should be changed in pair, I tried same once and next month changed the second one. I am totally surprise that why dealer has changed one, go back and ask them the reason, as you never know there must be some fault or a defect they must have spotted on one air ballon in which case changing the faulty one is acceptable. 1 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
shahryar2002 Posted May 31, 2017 Author Report Share Posted May 31, 2017 Removed unit. Cracks are visible over the strut. 1 Link to comment Share on other sites More sharing options...
Rahimdad Posted June 1, 2017 Report Share Posted June 1, 2017 Thanks for sharing @shahryar2002 and great advise from Gaurav, Desertdude, Barry and Derik. 1 Link to comment Share on other sites More sharing options...
desertdude Posted June 1, 2017 Report Share Posted June 1, 2017 so you can imagine the other one is also in similar shape 2 Link to comment Share on other sites More sharing options...
