Summer Off-road Adventures
Tire pressure deflation for off road driving
7 hours ago, Gaurav said:
For any type of off road driving in the UAE you need to reduce your 4x4 tire pressure. For mountains and wadi it's easy to reduce between 20-25 PSI irrespective of the tire brand, shape, type and load.
For sand the tire pressure deflation is little bit tricky and if you follow below steps, you can decode this better.
Before that you also need to understand that why deflation for off road driving is so important:
  • Deflated tires are hard to sink in or dig in the sand due to lesser resistance.
  • Deflated tires increase the sand flotation to reduce the load on Engine, 4x4 and Transmission.
  • By deflating tire pressure you increase the footprint, that help you stabilize & offer better directional control.
Image shows the two tires track: One with 35 PSI (left) and other with 12 PSI (right).
Finding a perfect tire pressure for off road driving for your specific tire and 4x4 is based on bit of learning and experiments. Of course the lower the tire pressure better it is for dune bashing, climbing and self recoveries but too low is also dangerous for popping the tire out of its wheel.
You can follow the below chart, if you are totally new to off road driving as an indication (ONLY).
  • If you have a pop out on normal driving, then increase 1 PSI next time to find the best tire pressure for your 4x4.
  • If your 4x4 is Long Wheel Base (LWB) with full load then increase 1-2 PSI more than below indications.
Type/Brand of Tire
Regular Driving
Intermediate Driving
Self-Recovering
All HT Tread
(Highway Tread)
Dunlop Grandtrek
Bridgestone Dueler
Yoko Geolander HT
Michelin Latitude
Pirelli Scorpion
Goodyear HT
14 PSI
12 PSI
(Avoid sharp steering)
8-10 PSI
(Inflate after recovery)
 All MT Tread
(Mud Terrain Tread)
Mickey Thompson MT
BF Goodrich MT
Cooper STT - MT
Nitto Trail Grappler MT
Toyo Open Country MT
Dick Cepek Extreme
 12 PSI
10 PSI
 6-8 PSI
 All AT Tread
(All Terrain Tread)
Yoko Geolander AT
Michelin Pilot A/S3
Hankook Dynapro
10-12 PSI
8-10 PSI
 4-6 PSI
Disclaimer: If you can't find your tire brand in the list then rely on HT / MT / AT section to be 90% safe.
For knowing how to deflate the tires, please speak to any of the Marshal or senior member to show you how its done properly. There are more than a couple of ways and tools off-roaders use to deflate depending on their choices. All tools, ways and method are correct as far as you achieve the correct tire pressure.
If you are new to offroading, I highly suggest to double check the tire pressure twice once you are done. Borrow the fellow offroader tire pressure gauge and check again, as many times your new gauge might go wonky and give false readings. Once you are 100% sure that your gauge is correct always, then you are fine to rely on your own readings.
PLEASE DON'T DEFLATE WITH KEY AND STOPWATCH AND ASSUME IT'S 14 PSI.
Secondly, always check / adjust tire pressure again after 30 minutes of sand driving as it might increase due to the heat and stress. If you are facing constant refusal at the beginning of any drive, I bet your 14 PSI has shot up to 18 PSI and you need to reduce the tire pressure more to bring it down to 14 PSI. This happens on almost every newbie drive, so it's fine and proven gazillions of time.
Very nice 👍 theory. Truly ready reckoner for all level off-roaders!! 👏🏼
  • 1 year later...
I wish to add that it is a good idea to wash the threads of the tyre air valves, pressure gauges or any other gadgets that screw on the air valves and occasionally replace the valve cores inserts, they cost next to nothing. Sands particles easily get into it and can ruin the threads and damage these valves causing even pop-outs when one loses few PSI. The ambient tyre pressure charts are excellent guides.
  • 5 months later...
I have a note to add to this thread. Even if there is no pop out its always good to check your tires for any sand intrusion inside the tires when you are driving on sand at lower pressures as sand gets inside the tires occasionally. I have a recent experience of this phenomenon. One of my tires was losing air from 35 psi to 12 psi and lower in a time frame of 2 days. I was bewildered and thought probably I managed to induce a hairline crack somewhere in the tire as 2 tire shops checked the tire for any leak after inflating to 60 psi and nothing was found. In the 3rd tire shop when I explained to the technician he immediately said there is a sand intrusion inside the tire and between the beads. He proceeded to remove the tire from the rim and surprisingly there was lot of sand between the tire bead and the tire. Probably it entered the tire when the tire was getting flexed by the constant sharp steering movements or hits on small bushes or by the jumps. This happened to the back tire and not the front.
I was under the impression that sand intrusion inside the rim will happen only during pop outs and this incident changed that perception completely. When we are driving on sand its always good to check for everything in the car preferably after at least 2 to 3 drives and make sure everything is in order so that we can avoid unfortunate incidents during the drive and bog down other drivers who have come there for fun and waste their time because we were lazy to take care of our own car.
@Thomas Varghese, when I recently replaced my tires I also noticed some sand inside, that explained why I was losing pressure slowly especially when I deflate the tires.
Edited by Lawrence_Chehimi
This is a great @Thomas Varghese@Lawrence_Chehimi observation and it happens specially on older tyres also after popouts the tyre must be cleaned thrououghly. In my experience we should regularly replace the inner tyre valves as well. they cost nothing.
  • Totally Agree (+2) 2
My tires are not old. Replaced them in 2021 Jan and has only run 25000 kms.
@Thomas Varghese you are a "Monster of Milage";  I thought only commercial vehicles do those kinds of numbers.
My rear left tyre started to deflate automatically after the last mystery drive. Since I was travelling, my better half (@Desert Wrangler ) took the vehicle to a couple of petrol pump tyre shops where they said there is no puncture but the valve seems to be the culprit and it will cost AED 130 for the valve replacement and need to order 2 days in advance. I was planning to install the rapid deflating valves anyways so gave the car to a shop and asked them to clean the tyres as well.
  • Similar Content
    • By Jefy
      Saw this add on Instagram, just wanted to share it with you.
    • By Jefy
      The modified car, the never ending story, the money pit.
      Anyway, I have ordered wheels with the correct offset from Europe and they arriving soon. I already have tires for them.
      I am looking for a reliable wheel balance/ alignment fitting garage, preferably south of Dubai.
      A shop that knows what they are doing with lifted suv’s.
      Please let me know.
      To come back to wheels with correct offset. What I don’t understand from our region. We have maybe the most LC200S driving around than anywhere.
      The lc200 comes with a positive offset of 60mm.
      Almost all shops they have only wheels with 0 offset. When I ask them if they have wheels with positive offset, they ask me again why I want positive offset. Because I want something that works? And not only look good, without chopping here and there???
      So thats why ordered wheels abroad.
    • By Rahimdad
      Set of 4 used:                   Once Vehicle used:                    Mitsubishi Pajero 3.8 Number of years used:    3+ Years Value for money:              5 / 5 On-road comfort:              5 / 5 Off-road performance:      4 / 5 Overall Performance:        4 / 5
      So it was time to go for a new set of tires for my wife's Mitsubishi Pajero and after a lot of research was in a lot of turmoil whether I should go for the Nitto Duragrapplers as tried and tested or a set of Kumho Solus KL21. Put the options to my wife and with the price point, she immediately jumped at the Kumho Solus KL21 set. I obeyed my wife and asked them to slap the Kumhos on, but deep inside I was waiting for them to fail and never thought that 3 years down the road and I would be writing a positive review on these.
      Kumho tires are a Korean brand and made in Korea so it makes you think twice about your investment. I drove them now for 3 years mostly on road except for a couple of occasions when I took them off-road in the sand for a short stint and here is what I think about the Kumho Solus KL21. On road they are really quiet and offer a very comfortable ride, they have a good grip on the road in all weather conditions and so far I have not seen any inconsistent ware in these tires. They have been on for 3 years with almost 70K Kms on the clock and I recently got them inspected, they always remained very smooth and quiet on-road and I now feel confident having them on as the tire shop told me there is quite a bit of tread left on them and no cracks at all. My main concern, however, came how it does perform off-road being a highway terrain tire? The honest truth is, being my wife's car I hardly took it off-road, but for what it is worth it performed well for a couple of short stints I was talking about earlier. The straight threads of a highway terrain help them float better in the sands, and they seem light (which is a big positive mark from the off-road side for stock cars). They have served me very well for over 70,000 kms so far and I am very pleased with their overall performance. They are still smooth, quiet and comfortable on-road even at 140 kmph and gives you good control with different maneuvers.
      In conclusion, I would only like to say, these are my first set of Kumho Solus KL21 on my wife's Mitsubishi Pajero and although I was not sold on these at the time of purchase these have most definitely impressed me. I am very happy to own the current set and feeling relieved that my wife had made such a great investment for the past 3 years and the remainder of the time to come. At the price point, they are very good performer on-road and very good value for money.
    • By aadilish
      Pitstop Arabia is a pioneer in selling tyres online in the Middle East and are headquartered in Dubai, UAE. Pitstop Arabia provides a new way for consumers in Arabia to acquire tyes, allowing them superior convenience and value.
      In a few easy steps, customers can complete the process of buying tyres selecting a time and place convenient to them for Installation. Customers have their tyres installed at their homes or office as well.
      Pitstop Arabia provides a large assortment of brands as well as sizes to cater to all Passenger, 4X4 and light commercial vehicles. Our growing network of Premium Installers are dedicated to delivering the highest standards of workmanship and customer service. Selecting a Premium Installer ensures that your vehicle is being looked after by leading technicians in the industry. Our Premium Installers are chosen and audited to guarantee our customers that they have exceeded our stringent criteria on capabilities, on-site facilities and customer feedback.
      Pitstop Arabia have set out to offer customers value and convenience they simply could not get any other way, bringing customers much more selection than is possible in any physical store. The information is presented in a useful and easy layout.
      Pitstop Arabia keeps prices competitive to further enhance customer value. We believe customer experience is the key to our company’s growth and we consistently engage with customers, always looking to improve and evolve our business processes to better suit our customers.
      We at Pitstop Arabia are obsessive about serving our customers: We measure our success not just in financial metrics but how satisfied our customers are. We firmly believe that a satisfied customer is the best marketing tool, so word of mouth remains our most powerful tool for acquiring customers. We are continuously striving to find new and better ways on improving your shopping experience.
    • By Sanddance TyresUae
      We provide special pricing for all Carnity members.
