samay Posted July 11, 2011 Report Share Posted July 11, 2011 i got the rear rotor disc replaced and even the pads as the were due to be changed. The ABS and warning indicator comes and stays on and after that the brakes work well with no noises nor any sensations from the brake pedal. When switching the car off and back on, the ABS system is reset and the procedure duplicates itself which I read the manual that explained the procedure of the ABS system will re-adjust after replacing parts, but this dose not appear to be settling itself. Link to comment Share on other sites More sharing options...
ansaari Posted July 12, 2011 Report Share Posted July 12, 2011 Change the brake sensor too, which actually communicate with the ABS block to tell that there is something wrong (brake finishing etc). If you have already changed the brake sensor in pad and drum and still getting this ABS light, it means that there is something actually wrong in brake lines, brake fluid system, ABS modulator (block) itself, Master cylinder. Get computerized check to read which fault code it shows. Diagnostic guys should able to read that code and translate into which part is faulty for you. Go to good garage mate. Link to comment Share on other sites More sharing options...
gardi Posted October 28, 2012 Report Share Posted October 28, 2012 i have a similar problem and i still have abs warning. Link to comment Share on other sites More sharing options...
ehsa Posted October 30, 2012 Report Share Posted October 30, 2012 ABS is safety feature so take your car to a good garage or to the dealer who will help you with this problem. Link to comment Share on other sites More sharing options...
