Foxtrot Oscar Posted May 31, 2021 Share Posted May 31, 2021 49 minutes ago, Niki said: Coming back here as being inspired by the Molle solutions, I had a local fabricator copy an online set of baskets I had seen, with thick enough aluminum to secure items in the future and use the space above the wheel wells more effectively. Just sharing here as this thread had a lot of contributors plus inspiration for me and will set up a mirror of this on the FJ forum as hijacking the ‘X’ forum, though fun, isn’t fair Very cool 2 1 Link to comment Share on other sites More sharing options...
Hisham Masaad Posted June 1, 2021 Share Posted June 1, 2021 8 hours ago, Niki said: Coming back here as being inspired by the Molle solutions, I had a local fabricator copy an online set of baskets I had seen, with thick enough aluminum to secure items in the future and use the space above the wheel wells more effectively. Just sharing here as this thread had a lot of contributors plus inspiration for me and will set up a mirror of this on the FJ forum as hijacking the ‘X’ forum, though fun, isn’t fair @Niki great job, I am struggling with the same, I made a mole panel and fixed it to the back door, but yesterday realized cause of weight, it is pulling the plastic door cover our. The water tank also is not fixed property by the garage and started coming out. Can you please tell me where did you make it? Link to comment Share on other sites More sharing options...
Ahab Shamaa Posted June 1, 2021 Share Posted June 1, 2021 Great addition to the car @Niki 👏🏻 Looks sturdy. Any issues with noise of aluminum rubbing against plastic? Hey @Hisham Masaad, the Molle on the backdoor cannot be secured to the plastic part of the door. The garage/you, will need to fabricate a metal/aluminum backplate, that bolts on to the metal part of your door. The plastic panel is then put on top for aesthetics (plastic won’t be supporting weight). With a metal backplate to support the Molle system, you’ll be good to go adding gear and equipment. Last thing to consider; the backdoor on the FJ has two hinges. The top one is heavy-duty and can take on the additional weight. The bottom one however, is light duty and will not take on the added weight (it gives/bends, and messes up the alignment of door), and therefor will have to be replaced with a sturdier one… Happy spending 🤣 1 Link to comment Share on other sites More sharing options...
Niki Posted June 1, 2021 Share Posted June 1, 2021 hey @Ahab Shamaa not at the moment however I was having some rattling which I found to the the factory tools for changing the tires moving around. I have emptied the baskets and tied these down and will test the noise this week and def let you know. The baskets are secured via plastic feet to the base also .. so no metal is touching the plastic body of the car. Let me test this week and give you some definitive feedback //‘happy spending’ 🤦🏽♂️ … this should be on your signature permanent … 1 1 Link to comment Share on other sites More sharing options...
Ahab Shamaa Posted June 1, 2021 Share Posted June 1, 2021 Hey @Niki, good to hear about the noise; or the lack of it 🤣 Rattling noises drive me crazy and ruin my concentration 😀 Yeah, let’s hear back from you after you put the new baskets to the test 😀 1 Link to comment Share on other sites More sharing options...
Rizwanm2 Posted June 5, 2021 Share Posted June 5, 2021 Hi @Ahab Shamaa @Foxtrot Oscar i heard both of you got the shovel mount for roof rack from Amazon. appreciate if you can share the link to the product. Thanks. 🙏 2 Link to comment Share on other sites More sharing options...
Ahab Shamaa Posted June 6, 2021 Share Posted June 6, 2021 Hey @Rizwanm2, there are two parts to this mount. The rubber clamp that holds the shovel: https://www.amazon.ae/dp/B092PH3NLR/ref=cm_sw_r_cp_api_glt_i_M5TN16HGQYJBAAPASCRW?_encoding=UTF8&psc=1 and the aluminum clamp to secure the rubber clamp to your roof rack: https://www.amazon.ae/dp/B07QGDXK4J/ref=cm_sw_r_cp_api_glt_i_CT756JDGDX18TDX1BQNX?_encoding=UTF8&psc=1 Good luck! 1 1 1 Link to comment Share on other sites More sharing options...
Rizwanm2 Posted June 6, 2021 Share Posted June 6, 2021 2 hours ago, Ahab Shamaa said: Hey @Rizwanm2, there are two parts to this mount. The rubber clamp that holds the shovel: https://www.amazon.ae/dp/B092PH3NLR/ref=cm_sw_r_cp_api_glt_i_M5TN16HGQYJBAAPASCRW?_encoding=UTF8&psc=1 and the aluminum clamp to secure the rubber clamp to your roof rack: https://www.amazon.ae/dp/B07QGDXK4J/ref=cm_sw_r_cp_api_glt_i_CT756JDGDX18TDX1BQNX?_encoding=UTF8&psc=1 Good luck! Thank you Ahab. 2 Link to comment Share on other sites More sharing options...
Ahab Shamaa Posted August 29, 2021 Share Posted August 29, 2021 Hey @PaoloMaraziti, I am still struggling to find a good solution for the monster Jack you and I own. I had bought the ProEagle mount, but it’s pretty useless in the FJ. Even after reinforcing my back door molle panels and the door hinges, the ProEgle proved to be too heavy to be mounted on the FJ’s back door. So for now, it’s sitting in the trunk on the floor and secured by ratchet straps… I don’t like the setup as it eats up the space in the back. I’ll keep on looking for a good solution, and if I find it, i’ll post it. I hope you do the same 😀🙏🏻 1 Link to comment Share on other sites More sharing options...
Hisham Masaad Posted August 29, 2021 Share Posted August 29, 2021 Good morning @PaoloMaraziti and @Ahab Shamaa, was looking at the Jack and looking interesting. You are most welcome @PaoloMaraziti for a cup of espresso, to look at the Jack and find a solution. @Ahab Shamaai was in a garage one day, and saw my things I put on the back door, and recommended not to put heavy things on the door. I opened the door internal cladding and made some supports, the issue was the final attachment to the door which stick weak. Link to comment Share on other sites More sharing options...
