Varun Mehndiratta Posted January 6, 2021 Report Share Posted January 6, 2021 Dears request advice on where I can find tail gate mount like these in Dubai? Request advice 2 Link to comment Share on other sites More sharing options...
Rahimdad Posted January 6, 2021 Report Share Posted January 6, 2021 @varunmehndiratta try Amazon, I found this one for JL, not sure if this will help. https://www.amazon.ae/Akozon-Foldable-Tailgate-Multifunction-Wrangler/dp/B08972TRL3/ref=sr_1_26_sspa?dchild=1&keywords=jeep+wrangler+rear+door+storage&qid=1609917611&sr=8-26-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyNkZCS05OWjdSRDVPJmVuY3J5cHRlZElkPUEwNjg3MTQwM1BKM0w3TlkwTE5SNCZlbmNyeXB0ZWRBZElkPUEwODY0NjI1MlFLUlY5STM3VEFKUiZ3aWRnZXROYW1lPXNwX210ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU= 1 Link to comment Share on other sites More sharing options...
Gaurav Posted January 6, 2021 Report Share Posted January 6, 2021 They are very common rubber mounts for mounting tools, you can search google to get plenty of options. Shovel rubber mount Quick fist rubber mount 3 Let's root for each other & watch each other grow. Link to comment Share on other sites More sharing options...
Varun Mehndiratta Posted January 6, 2021 Author Report Share Posted January 6, 2021 Thanks @Gaurav @Rahimdad based on your advice...found this... Looks really nice... By any chance some ideas to mount shovel without drilling into doors... 2 Link to comment Share on other sites More sharing options...
Rahimdad Posted January 7, 2021 Report Share Posted January 7, 2021 If you watch the video he has mounted the shovel and axe with Quick Fist Mounts, I think if I am not mistaken I have seen @Foxtrot Oscar use these to fit her shovel on the roof rail. However mounting the rear door storage securely you will need to screw that in. Nowadays there are many things introduced every day, keep looking and you will most certainly find something that fits. Keep an open mind while looking as many things can be for different uses, but you might just be able to use those products as you deem right. Just as an example when I started off-roading flag poles were hard to find and very expensive, so I used a fishing rod fitted with a glass suction mount to use as my flag. 3 Link to comment Share on other sites More sharing options...
Foxtrot Oscar Posted January 7, 2021 Report Share Posted January 7, 2021 6 hours ago, Rahimdad said: If you watch the video he has mounted the shovel and axe with Quick Fist Mounts, I think if I am not mistaken I have seen @Foxtrot Oscar use these to fit her shovel on the roof rail. However mounting the rear door storage securely you will need to screw that in. Nowadays there are many things introduced every day, keep looking and you will most certainly find something that fits. Keep an open mind while looking as many things can be for different uses, but you might just be able to use those products as you deem right. Just as an example when I started off-roading flag poles were hard to find and very expensive, so I used a fishing rod fitted with a glass suction mount to use as my flag. Yep, for the princely sum of 50AED 😎 1 1 Link to comment Share on other sites More sharing options...
Varun Mehndiratta Posted January 30, 2021 Author Report Share Posted January 30, 2021 (edited) Thanks all for your suggestions...finally got it done...as suggested Quick fist clamps and thanks to @Kailas advice cable ties to avoid drilling in (without this surely won't have gone ahead with concept). Thanks again all - stuck some bubble wrap at end just to avoid any scratch (though there is gap, just being Iextra cautious) ...perhaps will replace it with some rubber tip as soon find the right size for shovel. @Gaurav @Rahimdad @Foxtrot Oscar Edited January 30, 2021 by varunmehndiratta 1 Link to comment Share on other sites More sharing options...
luwaimn Posted January 30, 2021 Report Share Posted January 30, 2021 Try ali express or ebay.com. Deliveries might take around 15 - 20 days. but you shall get a lot of ideas and options. 1 Link to comment Share on other sites More sharing options...
Kailas Posted January 30, 2021 Report Share Posted January 30, 2021 @varunmehndiratta, Yeah this shovel is probably small, @Wrangeld calls them spoon😂. Try the 35 Aed Shovel from Speedex, it is big enough and fits the JL trunk. Cheers 2 1 Link to comment Share on other sites More sharing options...
Wrangeld Posted January 30, 2021 Report Share Posted January 30, 2021 1 hour ago, Kailas said: @varunmehndiratta, Yeah this shovel is probably small, @Wrangeld calls them spoon😂. Try the 35 Aed Shovel from Speedex, it is big enough and fits the JL trunk. Cheers @varunmehndiratta @Kailas I have a new motivation for anyone arriving with a teaspoon. All shoveling will be handed over. Sad to say, pretty, in this game, us not necessarily functional. 2 1 Link to comment Share on other sites More sharing options...
