Night Newbie Desert Drive - Qudra - Dubai - 7 Jan 2022
dune jockey
General Info
This drive is organized in full compliance with the COVID19 guidelines. We expect every member that joins this drive to go through the below information and strictly follow these guidelines in order not to jeopardise someone's health, and to ensure we can keep organizing these drives safely.
MUST READ AND TOTALLY AGREE:
General Info
Drive Details
Level:  Newbie and above
When:  07 January 2022, Friday.
Meeting time: 9 PM (SHARP - Without any exceptions)
Meeting Point: https://goo.gl/maps/CibEtTDATvfFhTBR8
Approximate finish time: 12 MN
P.S. Only join if you have a compressor to inflate your tires after the drive.
LIMITED SPOTS AVAILABLE
  • Limited to 12 cars only. RSVP will close on Friday, 2 pm.
PLEASE RSVP ON THE CALENDAR
5 hours ago, Markus B said:
Hello! This will be my first night drive, do we need extra offroad lights / a lit flag or are stock light and a normal flag fine?
Thanks Markus
Hi @Markus B. No need for off road lights, high beam with fog lamps is ok.
regular flag is okay, if you have a blinking led which you can attach  to the flag - simplest is the one u strap on a cycle is also ok ( not a must)
Hi friends
Please note the listing for tonight
We will use Chanel 1 for radio coms
Use Head lights in high beam with fog lamps after deflation for the drive
BE watch ful for creepers at night, see where you walk. In case of any refusals or stoppage, please be inside your cars for your own safety.
I will be calling out for members as and when needed for help when needed
See you soon
