Morning Fewbie Desert Drive - Tawi Nizwa - Dubai - 06 Apr 2024
Welcome to Carnity Off road Club Fewbie drive, meeting in Tawi Nizwa.
We request every member that joins this drive to go through the below information and strictly follow these guidelines, etiquettes and responsibilities.
Drive Details
Level:  Fewbie and above (all levels)
Meeting time: 07:00 AM (SHARP - Without any exceptions)
Meeting Point:  https://goo.gl/maps/NjBkdRiyDXGMhMHR9
Approximate finish time: 11:00 AM
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only.
  • Please withdraw your RSVP, if you find you are unable to join, so your spot can be taken by others on the waitlist.
  • If the RSVP is full, you can add your name to the waitlist, if an RSVP attendee removes themselves, you will be moved from the waitlist to the RSVP list as an attendee.
  • A convoy list will be sent out the day prior to the drive.
PLEASE RSVP ON THE CALENDAR
  • Gaurav changed the title to Morning Fewbie Desert Drive - Tawi Nizwa - Dubai - 06 Apr 2024
It’s quiet around here !  All all good for the morning @Davie Chase @Mark B @Benjamin
Thanks for another great drive @Davie Chase. Hope I'm still smiling come 5pm tomorrow with this shirt!
@Gary F @Mark B @Benjamin and @Imran Asghar did a great job dealing with all the stucks/refusals.
Thanks to everyone else in the convoy, was a good morning out in the desert, varied drive which proved tricky at spots.
  • Thanks (+1) 2
Hi Davie
Great drive mate and yes chilled today to be honest which in good with as the guys in the middle were fantastic at supporting all the issues! No complaints from me!
Think I figured it out
The throttle body is filthy because the air filter was faulty so process of elimination. When I put the AC on the load is straining the car as throttle body full of crap
So elimination process
1. New s and b air filter done
2. Throttle body cleaned again for the 3rd time in an month (because of the air intake)
3. Keep an eye on it and if it happens again then need to figure out why the throttle body keeps getting dirty
Last and not least get the snorkle resealed I noticed this when I stripped it down after the drive : (going to ravon thenguys that installed it to get resealed Tomo morning )
