CANCELLED: Morning Fewbie Desert Drive - Lisaili : GO TECH, BURN CALORIES !! - Dubai - 20 April 2024
DP1011
We request every member that joins this drive to go through the information below and strictly follow these guidelines, etiquette and responsibilities.
DRIVE DETAILS
Drive Plan :
With the conclusion of Ramadan series, shorter duration drive, this drive is a technical drive, testing the skills of handling small technical dunes that the desert of Lisaili offers.  The drive will require LOT of patience and Shoveling , hence its termed - GO TECH and BURN CALORIES. This will be a drive slightly faster than the pace of snail and hence the drive duration MIGHT get extended by 1 additional hour, so please ensure you plan accordingly.
The drive is for FB and above however considering the plan to cover technical patches, you can RSVP only if you have Completed with Carnity atleast 3 FB Drives in last 2 months.  Apologies to those who will miss out because of this filter - Feel free to join from the other 2 Fewbie drives happening on same day )
SOME basic RULES THAT WE ALL WILL RESPECT :  Meeting time and Mandatory gears per your level.
Level:  Fewbie and above (with MINIMUM 3 Fewbie Drives in last 2 months)
When: 20 April 2024, Saturday
Meeting time:  6.00 AM - Sharp
Meeting Point: TBC
Approximate finish time: 10.00 am (with buffer of 1 hour)
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm, and willingness to learn.
RECOMENDED OFF-ROAD GEAR:
  • Tire deflator & Tire pressure gauge
  • Compressor (MANDATORY)
  • Walkie-talkie radio (MANDATORY)
  • Off-road flag (MANDATORY)
  • Shovel, Tow Rope & 2 Shackles
  • First-aid kit
  • Fire extinguisher
LIMITED SPOTS AVAILABLE
  • This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM.
  • RSVP will close a day prior to preparing a convoy list.
  • Latecomers will be returned - Without any exceptions.
  • Members without RSVP will be returned - Without any exceptions.
  • Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others.
  • Repeated no-show members after RSVP will have their account suspended for a month.
PLEASE RSVP ON THE CALENDAR
  • Carnity changed the title to Morning Fewbie Desert Drive - Lisaili : GO TECH, BURN CALORIES !! - Dubai - 20 April 2024
1 hour ago, Ben Lee said:
Hi DP, hope you and all our fellow drivers got through yesterday ok. Unfortunately, my Jeep took some damage so I’m going to have to withdraw until I can get it looked at.
Thanks for letting me know @Ben Lee - Hope not  major issues ! See you soon in future drives !!
  • DP1011 changed the title to CANCELLED: Morning Fewbie Desert Drive - Lisaili : GO TECH, BURN CALORIES !! - Dubai - 20 April 2024
Hi All,
Due to recent heavy rain in the UAE and waterlogged conditions the desert terrain is currently tricky with muddy conditions, broken ridges, and hidden pockets, which isn't ideal for a safe adventure.
Hence, I am canceling this weekend's drive, look forward to seeing you all soon on the next one. @Joji varghese @Faraz94 @Shiju Raju
Please acknowledge by any emoji.
