Morning Fewbie Plus Desert Drive - Nahil - Series 40 : 3 Hours - Abu Dhabi - 8 Jun 2024
DP1011
DRIVE DESCRIPTION
Welcome to the Carnity Fewbie Plus Nahel drive. This drive may encounter some super soft with a lot of push required.
Series 40 - 3 hours - for those of you wondering what's this derived from: It refers to the closest approx. temp (degree centigrade) which at least half of the drive duration will be experienced, and hence 3 hours drive - which will Commence Sharp 10 minutes from the meeting time!
DRIVE DETAILS
Level:  Fewbie Plus and above
When: 08 June 2024
Meeting time: 05:30 AM (SHARP - Without any exceptions)
Meeting Point: https://maps.app.goo.gl/uoPKsJH8NAUYKdnS6?g_st=ic
Type of Car: Any proper 4x4 with front and back tow hooks and 8-10 inches of ground clearance.
What to bring along: Loads of water, snacks (for yourself), smiles, face mask, rubber gloves, enthusiasm and willingness to learn.
Approximate finish time: 8.30am
What to bring along: Loads of water, snacks (for yourself), smiles, enthusiasm and willingness to learn.
Mandatory off-road gears: Tire deflator, tire pressure gauge, compressor, walkie-talkie radio, off-road flag, shovel, Rope, 2 Shackles, first-aid kit and fire extinguisher.
LIMITED SPOTS AVAILABLE:
  • This drive is limited to 12 cars only. RSVP will close on Friday - 9AM.
Please RSVP on below calendar
  • Gaurav changed the title to Morning Fewbie Plus Desert Drive - Nahil - Series 40 : 3 Hours - Abu Dhabi - 8 Jun 2024
Dear Nahil'ians! 😁
thank you for showing your interest for this 5:30 am challenge! ( Confirmed and WL) members!
Can u pls react to this post with any of your fav emoji,  if you agree with below :
"5:40 We all as a convoy will commence the drive, and if anyone is late , we leave him behind and none of you will consider me rude😅🙏🏼!  - This means we all arrive on or before time and be ready for briefing 5:35! and This also means if anyone's GPS shows arrival time beyond 5:30, they leave a message or call me to say they are taking a U-turn back home"
Thank you!
  • Totally Agree (+2) 6
2 minutes ago, DP1011 said:
Dear Nahil'ians! 😁
Thank you!
 fair 🫡🫡🫡
Fair 🫡🫡🫡
Dear Confirmed & Waitlisted members !! - If you are sure to join the drive, please react with any reaction emoji - and if you are not sure, or tentative, please reply to this with a message "tentative". ( obviously there could be some last minute issues, but if you are already aware of it, pls do consider those now :D )
Reason : If everyone is confirmed , our very own @Looper has agreed to take split convoy so everyone is able to have a drive - However he has agreed to do this ONLY if its a certain number of confirmed members warranting split convoy ! hence this update, So we can accordingly let Looper also plan his satday morning. .
@Luke K P @Aser @Shaun J @Nizar Shawwa @Julien Recan @Frans M @Alexanderrr @Andrew John Melvill @Faraz94 @Zulfikhar Naiyar  + WL members  @Mahmut @Gautam Banka @Brett Eicher @Deepak Eswar @azad @Cristian.
P.S - If your car is in garage and have been promised to be deliver by Friday Or if you have a party on Friday night- These both falls under category "Tentative" ;) :D .
Also note - The drive is in Abu Dhabi, meeting time 5.30, start time 5.40am
Thanks
DP
  • WOW (+2) 1
  • Totally Agree (+2) 4
  • Well Done (+2) 2
Good morning Deepak, Thank you for including us WL, unfortunately I am unable to attend due to unforeseen commitment that has come up.
I wish you all an excellent drive and lots of fun!
On 6/6/2024 at 7:06 AM, DP1011 said:
@Faraz94 - Thanks for reminding -
Hope you can make it! 🤞
@DP1011 I have found a workaround, I will join 😁.
lastly, this would be my first drive there, where is the last fuel station before the meeting point?
https://maps.app.goo.gl/rTZhZknE9PS68wrZ6 - Here you go - the best option, which even I will be relying on.
The next one is slightly far, and you have to go past the meeting point and then take U turn/ Right turn to join : https://maps.app.goo.gl/7jSqSVbTK3NJurxR8
