Julien Recan Posted June 16 Share Posted June 16 What would be the best way to fix a flag on a pole ? Mine's stock from where I bought the pole and is bad quality plastic bits, causing the flag to fall down during the drive. Thanks in advance ! Link to comment Share on other sites More sharing options...
RiadJL Posted June 18 Share Posted June 18 I installed my flag with a couple of cable ties. There is movement of the flag itself but the flag pole I have has a stopper that keeps the flag from sliding down the pole. The stopper itself is just a piece of rubber (i think or plastic) that is held in place with another cable tie - should be possible to make something like this with the right size rubber gasket and a small cable tie or electrical tape. Below image from the internet of the kind of stopper I'm talking about. The stopper also moves but needs a bit of force to move it as the rubber doesn't slide too easily on the metal. 1 Link to comment Share on other sites More sharing options...
Luke K P Posted Tuesday at 12:19 PM Share Posted Tuesday at 12:19 PM Just zip tie it 1 Link to comment Share on other sites More sharing options...
JeromeFJ Posted Thursday at 06:18 AM Share Posted Thursday at 06:18 AM I changed my flag 2 weeks ago. I found rubber stoppers (designed for garden flags). one above, and one below, it works fine. I can give you 2 in a next drive or if you pass by Downtown/ Business Bay. DM 0588620942 2 Link to comment Share on other sites More sharing options...
Mike M. Posted Thursday at 06:30 AM Share Posted Thursday at 06:30 AM (edited) Hi @Julien Recan, your cheapest and best option is to zip tie it. You can use 3 zip ties in a row to make it rotating. I am sure you will figure it out once you put the first zip tie by what I mean that you need 3 connected to each other. A more fancy way of doing it which customized flags use are Rubber lined P clips. Offroading Flag poles usually need the 3/8" size. Here is one example of what I mean: https://www.amazon.ae/HSEAMALL-Stainless-Steel-Rubber-Clamps/dp/B07RVJYTQY?th=1 In general, the fastest, efficient and economical way is to just zip tie it. Hope this helps. Edited Thursday at 06:31 AM by Mike M. 2 Link to comment Share on other sites More sharing options...
Julien Recan Posted Thursday at 09:31 AM Author Share Posted Thursday at 09:31 AM Thanks @Mike M. exactly what I was looking for. 3 hours ago, JeromeFJ said: I changed my flag 2 weeks ago. I found rubber stoppers (designed for garden flags). one above, and one below, it works fine. I can give you 2 in a next drive or if you pass by Downtown/ Business Bay. DM 0588620942 Thanks @JeromeFJ. I assume these are similar to @Mike M.’s ? On 6/18/2024 at 7:19 AM, Luke K P said: Just zip tie it Wouldn’t simple plastic one slip down the pole over time ? On 6/18/2024 at 3:48 AM, RiadJL said: I installed my flag with a couple of cable ties. There is movement of the flag itself but the flag pole I have has a stopper that keeps the flag from sliding down the pole. The stopper itself is just a piece of rubber (i think or plastic) that is held in place with another cable tie - should be possible to make something like this with the right size rubber gasket and a small cable tie or electrical tape. Below image from the internet of the kind of stopper I'm talking about. The stopper also moves but needs a bit of force to move it as the rubber doesn't slide too easily on the metal. I think @JeromeFJ and @Mike M. rubber clips are the out of the box solution 1 1 Link to comment Share on other sites More sharing options...
Luke K P Posted Thursday at 09:52 AM Share Posted Thursday at 09:52 AM (edited) ive used two zip ties at top, two zip ties at bottom, pulled them tight. hasnt slipped on me yet, and i have a pretty big flag Edited Thursday at 09:53 AM by Luke K P 1 1 Link to comment Share on other sites More sharing options...
JeromeFJ Posted Thursday at 10:33 AM Share Posted Thursday at 10:33 AM Very similar indeed Mine (10 PCS Garden Flag Rubber Stoppers) have a nice flower shape 😅 1 1 1 Link to comment Share on other sites More sharing options...
Mike M. Posted Friday at 04:19 AM Share Posted Friday at 04:19 AM 17 hours ago, JeromeFJ said: Very similar indeed Mine (10 PCS Garden Flag Rubber Stoppers) have a nice flower shape 😅 @JeromeFJ you can always say that you were going after the design of the “fleur-de-lis” to make it more French and that was the closest design they had 🤓. Hope you have been keeping well! 1 1 Link to comment Share on other sites More sharing options...
Mike M. Posted Friday at 04:24 AM Share Posted Friday at 04:24 AM 18 hours ago, Julien Recan said: Thanks @Mike M. exactly what I was looking for. Thanks @JeromeFJ. I assume these are similar to @Mike M.’s ? Wouldn’t simple plastic one slip down the pole over time ? I think @JeromeFJ and @Mike M. rubber clips are the out of the box solution @Julien Recan a fastened zip tie will not slide down. I would recommend for you to go after the zip tie solution, also recommended by @Luke K P as it will do the job for sure. It all depends on ur preference of course. Link to comment Share on other sites More sharing options...
