varghesedxb
Huge sound from AC Fan
i bought a ford EDGE 2013 3 days back, when i switched ON the ac, the fan is producing lound noises, when i stand outside the car.
The car is very silent when i switched OFF the AC.
Also when i switched On the AC, hot air blowing under car ..
Any one have similar issues??
thanks
Matt
Well this isnt sounding like an issue, as AC needs lot of engine power to run and produce noise from engine, engine fan and AC fan outside the car. During this course it dissipate heat under the car. These both phenomena are pretty normal and you shouldn't get worried. If AC isnt cooling good inside the car and too much noise inside the car, then you should be worried else don't bother about outside, its normal. enjoy your car.
thanks
Matt
Did you get it fixed?
> thanks
> Matt
Why is this a problem??? This is not a problem at all. I hope you noticed how unusual powerfull the AC is after start-up for such a big cabin, even in full sun. The fan in the engine is very powerfull and is critical in dissipating the heat away from condenser so you sit cooler inside, even when idling. That is why you feel the wind/hot air under the car. The fan is programmed to run at full speed when you idle, once you drive it slows, and eventually goes off... until you slow down, when it speeds up again.
In case this situation doesn't affect your driving experience and I don't think that this is a big problem. Is the sound unbearable or just loud? It is normal for AC to produce sounds.
