Ale Vallecchi Posted April 14, 2025 Share Posted April 14, 2025 We request every member that joins this drive to go through the information below and strictly follow these guidelines, etiquette and responsibilities. MUST READ AND COMPLY Environmental Policy Offroad Flag Guideline Two Way Radio Guideline Off road Driving Etiquettes Emergency details for all off roaders Off Road Driving - Roles & Responsibilities Drive Details Level: Fewbie and above (all levels) Meeting time: 08:00 AM (departure time) Meeting Point: https://maps.app.goo.gl/bvmW2trEghw9ikHx5 - NEW!! Action Plan: While the Al Ajban area is starting to be better known to Carnity members, following 3 drives recently completed in its dunes, this time we'll try to connect successfully its pristine dunes to Little Sweihan, across the border into Dubai. The first time we tried the convoy had to turn around in front of a closed entry into a newly fenced in area. This attempt will see the convoy cross into Dubai from a different direction, which I hope will allow us to enter the triangular shaped set of cordons that constitute the beautiful area so called Little Sweihan. This is a wind-swept location, with plenty of tall dunes, of white/gold sand, in places close to each other, otherwise opening up in long and undulating sand canyons. Two quite diverse segments, separated by a no-man's land that we'll try do cross successfully, this time. What to bring along: Loads of water, snacks (for yourself), smiles, face masks, rubber gloves, enthusiasm, and willingness to learn. Approximate finish time: 12:00PM P.S. Only join if you have a compressor to inflate your tires after the drive. RECOMMENDED OFF-ROAD GEAR: Tire deflator & Tire pressure gauge Compressor (MANDATORY) Walkie-talkie radio (MANDATORY) Off-road flag (MANDATORY) Shovel, Tow Rope & 2 Shackles First-aid kit Fire extinguisher. LIMITED SPOTS AVAILABLE This drive is limited to 10 cars only. RSVP will close on Friday - 12 PM. If the RSVP is full, you can add your name to the waitlist, once anyone drops, you will be moved to the RSVP list. RSVP will close a day prior to preparing a convoy list. Latecomers will be returned - Without any exceptions. Members without RSVP will be returned - Without any exceptions. Please withdraw your RSVP, if you aren't joining, so your spot can be taken by others. Repeated no-show members after RSVP will have their account suspended for a month. PLEASE RSVP ON THE CALENDAR 2 Link to comment Share on other sites More sharing options...
Nicolò Posted April 18, 2025 Share Posted April 18, 2025 Ciao @Ale Vallecchi unfortunately I will not be able to join the drive. I'm sorry, hopefully someone can take my spot. 1 Link to comment Share on other sites More sharing options...
Ale Vallecchi Posted April 18, 2025 Author Share Posted April 18, 2025 Dear Desertnauts in preparation for the drive, in order to avoid bad surprises, as we had the first time we attempted to complete this itinerary, I have scouted the trickier area, that is along the Abu Dhabi/Dubai border. Unfortunately, on the Abu Dhabi side there is not even one opening in an endless concrete wall, running all along the E14 Al Faqa Road. Given this unfortunate constraint, I have decided to turn this one into a surprise drive! By tomorrow afternoon, I will decide if we'll keep the planned starting point, and plan the drive in the Al Ajban area all the way to Sweihan town, or if we'll change the starting point to the Faqa area, opposite E14. In the latter case, we'll explore the dunes that run along the E14 itself, and reach Little Sweihan through their cordons, which during the recce I have found quite interesting, relatively clean, but with quite a few groups of beautiful Ghaf trees, and quite a lot of camels roaming. KINDLY STAY TUNED, AND CHECK THE MEETING/STARTING POINT, TO SEE WHICH ONE IT WILL FINALLY BE. In the meantime, the convoy order will be the following: @Luke K P in Second Lead @Carl Stanley at #3 @Myrko at #4 @Amr J at #5 @B.K. at #6 @Andrew John Melvill at Center @vinayak at #8 @Martin M at #9 @Johannes Roux at #10 @Yurybel at #11 and @Aser i Sweep. Please, do not forget to double check the meeting point tomorrow afternoon. In the meantime, enjoy the beginning of the weekend. 2 3 Link to comment Share on other sites More sharing options...
Martin M Posted April 18, 2025 Share Posted April 18, 2025 Hi @Ale Vallecchi, I'm really sorry but I am unable to attend the drive. Reading your teaser for a surprise drive, I really regret I'm unable to join. Enjoy the drive and see you soon. 1 Link to comment Share on other sites More sharing options...
Andrew John Melvill Posted April 19, 2025 Share Posted April 19, 2025 12 hours ago, Ale Vallecchi said: Dear Desertnauts in preparation for the drive, in order to avoid bad surprises, as we had the first time we attempted to complete this itinerary, I have scouted the trickier area, that is along the Abu Dhabi/Dubai border. Unfortunately, on the Abu Dhabi side there is not even one opening in an endless concrete wall, running all along the E14 Al Faqa Road. Given this unfortunate constraint, I have decided to turn this one into a surprise drive! By tomorrow afternoon, I will decide if we'll keep the planned starting point, and plan the drive in the Al Ajban area all the way to Sweihan town, or if we'll change the starting point to the Faqa area, opposite E14. In the latter case, we'll explore the dunes that run along the E14 itself, and reach Little Sweihan through their cordons, which during the recce I have found quite interesting, relatively clean, but with quite a few groups of beautiful Ghaf trees, and quite a lot of camels roaming. KINDLY STAY TUNED, AND CHECK THE MEETING/STARTING POINT, TO SEE WHICH ONE IT WILL FINALLY BE. In the meantime, the convoy order will be the following: @Luke K P in Second Lead @Carl Stanley at #3 @Myrko at #4 @Amr J at #5 @B.K. at #6 @Andrew John Melvill at Center @vinayak at #8 @Martin M at #9 @Johannes Roux at #10 @Yurybel at #11 and @Aser i Sweep. Please, do not forget to double check the meeting point tomorrow afternoon. In the meantime, enjoy the beginning of the weekend. @vinayak n please check the post from Ale 1 Link to comment Share on other sites More sharing options...
vinayak n Posted April 19, 2025 Share Posted April 19, 2025 @Andrew John Melvill noted 2 Link to comment Share on other sites More sharing options...
Ale Vallecchi Posted April 19, 2025 Author Share Posted April 19, 2025 Dear Desertnauts. As mentioned yesterday, I have concluded that it would make for a more interesting drive to surprise you with a new meeting point and a revised drive plan. We'll meet along E14, a bit closer to Faqa's side, to explore the south-eastern reaches of the Dubai emirate, and aim to end our drive at Little Sweihan (Dubai side) or perhaps at Ghantoot (AD side). I haven't driven in this area for a while, and would like to see if it has changed, or has maintained its characteristics, with long dunes, rolling cordons, some technical areas and frequent encounters with Ghaf trees and camel trains. Be ready for a medium/long drive. The new meeting and departing point is: https://maps.app.goo.gl/bvmW2trEghw9ikHx5 Looking forward to seeing @Luke K P @Carl Stanley @Myrko @Amr J @B.K. @Andrew John Melvill @vinayak @Johannes Roux @Yurybel @Aser tomorrow. Have a nice Saturday evening. 5 1 Link to comment Share on other sites More sharing options...
Andrew John Melvill Posted April 19, 2025 Share Posted April 19, 2025 Hi @Ale Vallecchi is the drive start time still 8am? Link to comment Share on other sites More sharing options...
Ale Vallecchi Posted April 19, 2025 Author Share Posted April 19, 2025 17 minutes ago, Andrew John Melvill said: Hi @Ale Vallecchi is the drive start time still 8am? Yes @Andrew John Melvill. Confirmed at 8 AM. Thanks 1 Link to comment Share on other sites More sharing options...
Aser Posted April 20, 2025 Share Posted April 20, 2025 Lots of animals and learning! I can't wait to see @Johannes Roux pictures. Long drive! 😅 1 1 2 Link to comment Share on other sites More sharing options...
