kukanoo Posted September 25, 2011 Report Share Posted September 25, 2011 I want to fix my passenger door that is not opening from inside and i need a diagram please. Link to comment Share on other sites More sharing options...
neil Posted September 26, 2011 Report Share Posted September 26, 2011 Remove the door panel and unlock the door look for the rod on the door. Link to comment Share on other sites More sharing options...
ROJ Posted September 27, 2011 Report Share Posted September 27, 2011 Its not that hard.. Once you access whats behind the door panel.. You will find out that most likely one of rods attached to the door handle is lose.. Link to comment Share on other sites More sharing options...
edison Posted September 27, 2011 Report Share Posted September 27, 2011 You can only find diagram for electrical parts, but sadly there is no big electrical gizmo behind the door panel. Open the door panel and explore. Worst you got to change the lock, its cheap i think 55 dhs. Link to comment Share on other sites More sharing options...
